School me on wastegates.
    Need 1 for my t4 .60 ar turbo.
    Will not be running over 7-8psi.
    What do I look for, and what dictates what I need?
    ******searched, really did not get the answer I was looking for********
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
    TIAL F38 should be fine (better to get original one)
    Good Luck ,,
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
      Well, you will need one with an 8lb spring to run 8psi of boost assuming you will not be using a boost controller.
      General rule is if you are running low boost, you want a larger wastegate(44mm).
      It needs more expulsion of gasses that you aren't utilizing in boost, so it needs to be bigger.
      If it is a higher boost application where the larger turbocharger is within its efficiency range, you can use the smaller wastegate because you're not expelling much exhaust gas.
      1991 325iS turbo
        That's a perfect explanation.
        Thanks!
