m50 turbo clutch questions
    So I have a 91 e34 nv m50 and I have a 92 e36 getrag tranny that i am currently resealing for boost
    what i need to know is what is the best option for a reliable clutch setup?
    ill be in the 300-400 range, Id like to stay with a single mass flywheel
    Also since i bought the car swapped its always had a problem with the clutch release, so does anyone know which release arm is needed?
    I have lots of questions to come and it seems a lot of people on here are starting this same project, so any and all help is appreciated
    I will be starting a full build thread with pictures as soon as I make a little more progress. thanks
    I will be running a similar power range with my s52. I kept my dual mass flywheel, had it refinished though, and from the amount of research i did the SOuthbend Stage 3 clutch was the best option. installed it and couldnt be happier. Supper grabby.
    oh, and i used the clutch slave cylinder that game with the 97 m3 zf. hope this helps.
    pm'd with more info.
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
      My plan is to use a e36 m3 clutch and flywheel
      This should hold everything and the price isnt bad
        yea the m3 clutch is pretty strong
        my brother has had the m3 clutch in his turbo m50
        for two yeas now only slipped on him once on freeway 3rd gear
        he is also running 15 pounds boost
        my build thread:http://www.r3vlimited.com/board/showthread.php?t=232324
          That's impressive! From what I read I figured the m3 clutch couldn't hold after about 300whp. What kind of numbers is he putting down oh and What turbo/fuel system is he running?
            Ya thats good to hear, i sorta assumed the same around 300 , i plan on starting at 7 psi
            Also, while i was doing the head gasket I went ahead and port and polished the head, Anyone know how much a port and polish will add to the m50t?
              not shure what management he he is running
              but here is a video of his dyno/build
              he also has a uuc stage 2 light flywheel if the matters
                I'll be installing a gripfore stage 3 clutch disc and pressure plate (modified sachs unit) with a sachs TOB and AASCO flywheel. I'm hoping it can hold up to 500whp as claimed.
                www.gecoils.com
