Best bang for your buck question
  • dmjensen
    • Jan 2011
    • 805
    alright so my e30 has been on 10psi for awhile now and i want to bump that up possibly, what would be the best way to beef up my motor? as far as the bottom end goes.
    I already plan on getting arp studs and cometic hg. but for the bottom I'm not quite sure what route to take, replace rod bearings and the main bolts and get new piston rings on? or just replace everything with new (pistons, rods, bearings, bolts, so on)
    I would like to be able to run somewhere in the 14-17 psi range. and im using a miller set up ( which i know is a bad idea so please save your comments about that for somewhere else.)
    thanks fellas :up:
  • devon.818
    • Feb 2011
    • 2937
    stock internals can handle like 22psi...
    frozen solid is makeing 440whp on stock internals buddy. at 18psi
    o-ringed block and arp studs with stock HG. leave everything else stock.
    • dmjensen
      • Jan 2011
      • 805
      really? that's insane
      • blueapplesoda
        • Dec 2005
        • 1904
        Yes, leave it all stock. O-rings and ARPs is the key. Hell metric blues work. Use the OEM goetze gasket.
        Derek
        • dmjensen
          • Jan 2011
          • 805
          i currently have metric blues and a vicreiz oem head gasket i think
          • The Humjet
            • Jun 2010
            • 528
            Keep boosting, keep tuning.
            • ak-
              • 12422
              arp connecting rod bolts for more insurance would probably be it as far as bearings and rings.
              1991 325iS turbo
              • dmjensen
                • Jan 2011
                • 805
                so just get it reringed, new bearings and bolts and im good to about 18psi is what im getting
                • jekaio
                  • Jun 2008
                  • 89
                  if you have solid tuning, then yes.
                  • dmjensen
                    • Jan 2011
                    • 805
                    i currently have 30lb injectors, how far can i go with them before i start putting them at there fully duty cycle/ start leaning out?
                    • blueapplesoda
                      • Dec 2005
                      • 1904
                      They are supposed to max out around 300whp. more like 265 though...
                      But if you raise fuel pressure during boost, you can cheat
                      • dmjensen
                        • Jan 2011
                        • 805
                        hmm.. so if i get a w255 pump and an adjustable fpr i could cheat and not get different injectors?
                        edit: i just realized i have a 38mm tial wastegate and the biggest spring i can find is 1 bar so that's probably as far as i'll take it because i don't want to upgrade wastegates
                        • FrozenSolid
                          • 276
                          i have a 38mm tial also, with a ~8psi spring. you can keep the same spring and wastegate just get a manual boost controller.
                          • einstein57
                            • Jun 2007
                            • 10780
                            get rid of that victor reinze and get a goetze or elring headgasket.
                            Bearing and o-ringing is not a must but is good insurance.
                            Why not just sell your injectors and by some 42lbers. You'll probably save money over getting a new fuel pump and FPR. Go on ebay and buy a small yellow tial springs (3.626). That stacked with your 1 bar spring will give you 18psi.
                            www.gecoils.com
                            • dmjensen
                              • Jan 2011
                              • 805
                              blew my vicreinze gasket yesterday LOL
                              and since it blew it some how added compresion to my coolant system and blew my lower radiator hose off, spilling all of its contents while doing a 4th gear pull, going 100mph, while i had a laptop in my lap, with my friend driving.
                              thank god for flatbeds <3
