Oil feed fitting question - M42
  • shEck3lls0
    • Jan 2011
    • 1154
    I have a question regarding the fittings for my turbo setup I will be running on my m42. I will be running the supply off of the stock oil pressure sender switch. I know that that location is an m12x1.5. Now my questions are as follows.
    Where can i find a correct T-fitting(or Y) to still run the stock sender as well as the supply for the turbo? All I can find is fittings with only AN and standard size fittings on them, nothing metric.
    I also plan on running a oil pressure guage in place of the stock sender relatively soon. Is it adviseable to continue to run that switch, or will I be fine without it if I have a gauge? (I guess my question is, will this mess with how the engine runs? I will be running megasquirt)
    Also, for the oil supply line (which I will get the size for you in a bit), should I be running a reducer to keep the pressure down? Or will it be fine without one?
    Thanks in advance. :)
    1989 Alpine 325is 2dr m50 swapped
    Build Thread:
    Current ongoing build. Check it out!
    1991 318is 4dr rallycross
    Rallycross Build Thread.
    1991 Alpine 318is coupe - sold
  • blueapplesoda
    • Dec 2005
    • 1904
    You could run that part.
    And the restrictor is a must when using a ball bearing turbo, or any gt style turbo. However, I've run -3an oil lines to journal turbos and there were no leaks.
