im running 17lb of boost, 36lb RCA injectors, vortec fml 12:1 ratio
my question is how do i figure out if im having a detonation problem, i retarded the timing once becore and could hear it loud and clear but it ran ok but idle'd like shit. so i reset the timing to stock and it still runs very good and the idle is alot better, but i can still here it detonating but its not as bad. so now im thing about advancing the timing by 1 tooth and seeing how it runs,
AM I ON THE RIGHT TRACK OR IS THERE A EASIER OR BETTER WAY TO DO THIS??????
P.S. OF COURSE I AM CHECHING TO MAKE SURE THE VALVES WONT HIT THE PISTON WHEN BEFORE I PUT EVERYTHING BACK TOGETHER..
