My old metric blues held up pretty well for the past 3-4 years, but i do recommend to buy new ones if you have to pull the head, i belive mine were fine the first two times but not the third, just pisses me off because i allready had 5 torqed down .. lol
m20 arp studs
Closest thing is Black-Oxide M10x1.5 150mm Length Spacer Stud. McMaster-Carr Part # 93275A046 = $2.79/ea
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
EDIT: Hmmm.. looks like ARP head studs are also Black-Oxide steel.. if these work then lots of people have been getting butt raped @ $225 a pop.Last edited by RobertK; 04-17-2012, 02:50 PM.Comment
M10x1.5mm 150mm Length... That's how I found the stud kit on McMaster Carr but in this case the 175mm stud would give you 25mm extra length for the nut to thread on.
You use the same hardened washers you would use with stock or metric blue bolts.Comment
