If I put a smaller pulley to spool the compressor quicker. Is there such thing as a cut off valve to stop it going past 8 psi?
Does R3V want a m20 supercharger kit?
Maybe you could use a blowoff valve like the turbo fellas use. Idk about centrifugal charger setups.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
I think they make whats called a bleed off valve similar to a wastgate but is similar to a Bov in design, it will vent pressurized air into the atmosphere at a certain psi to prevent overboosting. However that said a supercharger is very easy to control boost by itself with the adjustment in the diameter of the pulleys so I see no point.
Im trying to design a reliable compact, bolt on centrifugal vortech v9 system that will have boost at low rpm and waste excess pressure to hold steady at 8 psi. E.g. 12 psi pulley tuned inline with waste gate to hold 8psi but obviously quicker spool up. I want this to be daily driveable be setup properly once and forgotten it was even there.Comment
You can doit.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
Ok so cut the crap my idea in theory of smaller pulley for quicker boost and waste off to hold max of 8 psi will work but not reccomended by any sc manufacturer. Raptor v sc is the one I will be using since there Australian made and are of great help send me a dumby sc to make a mock up on.Comment
Yes, let's cut the crap. Go do it, then report back.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
Ether-d shut up, I havent seen you yanks atempt any good sc kits hence why im doing it from scratch for myself. If its good then your going to reap the benefits of having an m20 sc kit option. I suggest you drop the attitude and be more supportive than a smart arse. And if you wana have a sook go ahead because in Australia we'll tell you to " harden the f**K up mate! "Comment
Wow. You guys are tough down there. I better watch out. You might just build a kit on my ass. Also, I've only made supportive comments. And what does "have a sook" mean. And why don't you just say FUCK down there? What's with the asterisks?Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
I need this in my life. Please let there be an m90 or m62 supercharger kit. I would buy that kit so fast id be in debt before I knew it. I know the m90 is a popular option for SC'ing the m20, and its been done enough times to create quite a bit of info and knowledge for guys like me that want to do it. But a kit... a kit would be a dream come true.Comment
It did not. A lot of people want to buy a kit like this, but when it comes down to it, just a very small amount of people actually will buy one.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
