so last week i picked up my m20b25 engine. 180tho km's on it. not too bad given its age. its just over 100tho miles.
its obvious parts of it had been apart before. the front housing is siliconed, as is the water pump. but the w/p is new as is the cam belt. so i wasnt too worried.
so far ive stripped it down to have everything cleaned and the gaskets all replaced.
i performed a leak down test on it as the guy i bought it off failed to have a compression test done before it was removed.
results were
cyl 1- 5 between 10-15%. thats good as i thought as ive see worse on way newer motors. but cyl 6 came back at 85% out the inlet. turns out it was just a bit of loose carbon sitting under the valve. thank god for that.
so now i have the head apart and dismantled im going to reseat the valves. and have it resurfaced and cleaned and vac tested.
is there anything else that you recomend i have done?
the head is a genuine bmw 885. so the ports are already much nicer then the amc ones. i dont think i need bother with port work. and im trying to keep it on a budget. the ports are really clean so its been a nice clean runner and the valves are clean to match.
the bores are mint. good hone marks still very obvious. no upper cylinder wall lip. everything looks in good condition. so my thoughts are that since the leak down was so good, the bores are so mint i thought to leave it alone and bolt it back together once the head comes back.
ill be using a mls head gasket and arp studs and bolting it all back together with all new genuine gaskets everywhere else.
ill post pics as soon as i can. anything anyone recomends?
like the best place to take water/ oil feed/ return lines from for the turbo?
or just anything in general.
thanks, leigh. ill keep updating as parts arrive and i do more with it.
results were
