Does anyone make a Feed/Drain oil line kit?
  • Mr. Burns
    • Aug 2011
    • 3516
    instead of piecing each fitting one by one, i'm hoping that someone out there has a ready to buy kit that offers everything pre-measured up with -3an/-4an fittings.
    *edit* for M20b25 engine, t3/t4 turbo .63AR
    anything?
    *searched, no dice.
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • Cyrix2k
    • 593
    check ebay. You'll still need to have a fitting welded into your pan or tap the block.
    1997 540i/6 - stock
    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
    • JCarp90
      • Feb 2011
      • 1759
      I searched and searched. Never found one.
      • The Humjet
        • Jun 2010
        • 528
        Check out Jordan's turbo thread on e30tech, I like his oil feed setup. He also gives part numbers so its easy to chase up what parts he used.
        • Cyrix2k
          • 593
          I'm using something like this one
          You still need a couple extra parts, but not much. On the m20, I used an oil filter sandwich adapter.
          1997 540i/6 - stock
          • blueapplesoda
            • Dec 2005
            • 1904
            I posted this to Mr. burns ia PM, but thought I'd like to share what I use in my oil feed/drain kits. I don't actively sell them because my margin is basically zero for this kind of stuff, but if you need it I can get a hold of all the parts to take care of you.
            All that's needed is that I need to know what your engine, manifold, and turbo are to give you a correct kit. The base kit (bare minimum, without oil drain flange) is $120 plus 8.95 flat rate for shipping, depending on what parts you need.
            Comes with:
            27.50 - 3an stainless feed line
            34.95 - oil pressure adapter
            4.95 - turbo oil feed adapter (depends on turbo)
            13.90 - 2x 8/10an pushlock fittings
            15.00 - 2 ft 8/10an aeroquip drain hose
            8.00 - 1 ft 8/10an firesleeve
            12.00 - 8/10an 45/90/180 bulkhead
            2.45 - 8/10an lock nut
            1.25 - 2x 8/10an bonded washers
            120.00 - turbo oil kit, minus drain flange.
            Optional:
            30.00 - turbo oil drain flange, gasket, and hardware (depends on turbo). 8an or 10an
            For top mounted turbo's, sometime the drain is too close to the manifold/flange or turbine housing, and the provided fire sleeve is not enough. Usually with Garrett/replica GT turbos I have encountered this issue with. I have an extension kit that will extend the turbo oil drain
            with a 8an or 10an stainless steel hard line. Drain extension kit some with:
            45.00 - 6" 8/10an stainless hard line
            5.00 - 8/10an union (male-male)
            I also have water lines kit for watercooled gt turbos.
            35.00 - 2x 14mm extended banjos with 45 degree bends
            15.00 - 2x 14mm banjo bolts
            2.00 - 4x 14mm sealing washers
            9.00 - 4x ABA hose clamps
            20.00 - 8ft 5/16 hose
            Thanks!
            Derek
            DedericMS
            • BMWZ318is
              • Nov 2008
              • 102
              i found mine on ebay thats my best guess unless you have a performance shop near by that keep that stuff in stock
              • Mr. Burns
                • Aug 2011
                • 3516
                Thanks everyone, and Derek PM returned
                • MF DOOM
                  • Apr 2012
                  • 944
                  • Cyrix2k
                    • 593
                    I'll vouch for silicone intakes - I ordered silicone couplers from them and they came quickly. Their stuff it pretty good quality too.
                    1997 540i/6 - stock
                    • custom e30
                      • Nov 2009
                      • 347
                      i turned my check oil tub into a bong, so down at the bottom it, return line runs around the front of the engine to the bottom of the tube,
