turbo supplies
    turbo supplies
    ok, so far i started my car. turbo is bolted on, rough idle. i can get that sorted in a while. i still need to weld an exhaust, get the wastegate on, tune, sex
    going for 400hp
    already have:
    M50
    stage 2 clutch+lightweight flywheel
    stock ecu
    stock fuel pump
    straight pipe headers for now
    arp head studs
    bov
    fuel regulator
    wtf is an oil catch can?
    guages
    IC/piping/turbo/oil lines/
    shopping list:
    .140 headgasket--------o-ring?
    injectors (what size?)
    can i run the oil pressure guage off the stock oil pressure sensor (i.e. fuse the wire to it)
    would i need to upgrade the fuel pump, i guess i can find out later. what is an oil catch can and what size injectors do people run? or should i just ask the tuner these questions when i get my car there? can i use the stock ecu? not sure if its the blue sticker or whatever
    Confused...you already have an oil catch can but don't know what it's for?
    Did you do anything with the ecu? Chip? The rough idle could be a lot of things.
    400hp...what are you going to do for the clutch? What size exhaust are you going to build? What are you doing for headstuds? Lots of people have GREAT results oringing the block and using an OEM headgasket with metric blues/ARP studs.
    Why are you trying to tap into the existing oil pressure sensor?
    Where are you going to get the oil feed/drain? I'm assuming this is for an m20...
    Not trying to be rude...just wish I had answered all of these questions before I started my build.
      i have no idea what it does or where the oil catch can goes,
      the ecu is stock, i'll have to check that out. the idle is probably because of random vacuum lines disconnected and o2 sensor being disconnected
      i already have some sort of stage 2 aluminum clutch/lightweight flywheel.
      i have some sort of new exhaust the PO put on it. I'm thinking about removing the cat tho. I already have arp head studs. forgot to mention.
      is it difficult to o-ring the block? i heard it works well but is it really worth it? I guess you get to keep the higher compression instead of dropping it with the .140.
      I want to use the oil pressure wire for my oil pressure gauge is all. wondering if it's accurate.
      oil feed/drain is good. its for an m50. my B. i forgot all about the important things
        Must do something with the ecu! For 400hp >> Standalone (Megasquirt,...) or at least Apexi S-AFC
        Must upgrade the fuel pump, it'll definitely wont handle the 400hp
        Forget about the fucking oil catch can ..
        O-ring the block with stock hg & ARPs
        500cc injectors at least
        What turbo do you have? What wastegate? What exhaust size?
        M20B28 Turbo
        My Build Thread
        http://www.r3vlimited.com/board/showthread.php?t=255839
          doing something with the ecu... what does that mean? buying a different one? or does it just mean reprogramming it or something
          ok, i guess i'll buy a walbro 255 fuel pump.
          fuck the catch can? ok, ill turn it into a flower vase or something
          i will also o-ring the block. I guess most any shop can do it right?
          500cc injectors at least? does that mean there are better?
          I have a turbonetics T3/T4 T04E .63AR
          38mm wastegate, i believe i can adjust it from 7psi to 15. exhaust size... hmm... it looks like just a 2" diameter. not stock though. no resonators and i'm going to cut out the cat
            For your goals you'll need a standalone engine management system, added to your stock ecu and then TUNING is a very important key!
            walbro 255 fuel pump is fine
            off course there are bigger (not better) injectors than 500cc, each size is capable for specific hp, but it depends on so many other things..
            2" exhaust?! It's too small for turbo applications and for 400hp!
            Before doing anything, READ everywhere to improve your knowledge and to know what are you doing
            M20B28 Turbo
            My Build Thread
              a standalone engine management consists of what? is it like a program or like a metal box with some wires in it that does magical things?
              what if i just leave the down pipe as the only piece of exhaust?
                No offense but use the search button and go on e30 tech and do some reading...they have some good turbo threads. And judging by some of your answers you really need to do a lot more homework.
                You can't just bolt a turbo and expect it to make 400hp....expect to lay out another few thousand for a stand alone, tune, exhaust, head gasket, o ring, arp studs, wideband, and a boost controller... among a few things
                Sent from my Galaxy Nexus using Tapatalk 2
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                  my biggest worry is your chasing what is effectively a shit load of power and you have no idea about any of it.
                  have you ever been behind a wheel of a car with that kind of get up and go? for more then 2 seconds of a friends car.... i mean have you OWNED a car with this kind of power? im guessing not.
                  my advice to you is keep your build alive. but start you aim lower. go for 250hp and build from there. get used to the car. the power. how it drives. then start scaring your friends. lol
                    i'll start without oringing and just the arp studs. stock fuel pump. ill keep it at a low boost. would i need a different tune every time I increase the boost little by little. or can i just cheapo my way through it without a proper tune for the beginning?
                    or can I get a solid tune, but keep the boost low. although then it would run rich...
                      If you're going to do it once, do it right the first time. No reason to not oring if you're already pulling the head for a new headgasket. Lots of guys have had their heads oringed and had no trouble.
                      If you raise the boost you will need a new tune if you want the motor to last/make the most power.
                      If you get a solid tune for low boost it won't run rich.
                        a standalone engine management consists of what? is it like a program or like a metal box with some wires in it that does magical things?...
                        7speedshop.com
                          do you think it would blow up without a tune at 300 at the flywheel? i know its a stupid question. i just want to drive it before i get all the necessary components
                            You won't make 300 hp without a tune. Don't start the build until you get everything you need and have a decent understanding of what every part of the turbo system does. More then "a standalone engine management consists of what? is it like a program or like a metal box with some wires in it that does magical things?..."
                            E30tech has a wealth of knowledge. e30tech.com. Check it out.
                              You won't make crap without the proper equipment and even with the right stuff without a proper tune you'll be replacing an engine.
                              Please do your homework before you proceed.
                              Driving it requires the right components and at least a base tune to get to a person that can properly tune it. Expect to spend nearly 1k on dyno/tuning
