turbo supplies
  • Pl3wA
    • 1589
    guys, the thing is... I'm 6 months into this build... :(
    • FLG
      • Sep 2011
      • 3165
      You really needed to do this homework prior..
      But you can still do things right since nothing is blown up yet lol
      You should o ring the block but you don't need to. A proper tune with arp bolts and even a stock head gasket will work... But there's a huge Emphasis on having the right tune.
      Your going to need an exhaust.... 3" perefebly.
      Your going to need to do something for management, look at Megasquirts stuff. Make some phone calls go on e30tech and look at some builds and diy's
      Sent from my Galaxy Nexus using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • sayed ali
        • 762
        I've completed more than 1 year putting things together correctly although the engine is in and o-ringed and everything ..
        Be patient, READ and LEARN what are you doing, don't waste your time and mind asking silly questions, do it right (perfect) or stay away of turbos
        M20B28 Turbo
        My Build Thread
        http://www.r3vlimited.com/board/showthread.php?t=255839
        • jaywood
          • Jul 2010
          • 4528
          I am guessing this car isn't your DD...so a few more weeks/months to do it right should be worth it.
          I have commented in a few of your other threads. You NEED tuning. You have to have a nice tune. Get megasquirt. PM "whodwho" here on r3v and get talking to him. He has a very nice PNP system that you can use.
          • Hey_You
            • Nov 2009
            • 963
            Im still in the holiday spirit. Don't tune it, run as much boost as you can, I want to watch some more fireworks!!! :)
            85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
            • Pl3wA
              • 1589
              this car is my dd lol. i've been using that crappy hyundai thats been chilling in my yard for the time. I'll give whodwho a pm once i get a megasquirt system.
              • Cyrix2k
                • 593
                yes, listen to these people. Also, if you don't already have a wideband, get the AEM UEGO NOT the Innovate LC-1. For injectors, 500cc might be a bit small - 60lb/hr injector would better fit your HP goals.
                You can play with the calculator here. Fuel pressure is 3.5 bar/52 psi
                1997 540i/6 - stock
                1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
                1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
                • MF DOOM
                  • Apr 2012
                  • 944
                  I believe blueapplesoda builds megasquirts as well.
                  Catch can runs from crankcase vent to intake. google.
                  A tune is the most important part. Theres a guy on e30tech thats hitting over 400hp/tq on a bone stock m20 with 20 or so psi. and take it to a pro for the tune. Ive been holding myself from turning the boost up and attempting to tune myself but i know id fuck something up. fuck patience.. but its worth not breaking something
                  • ak-
                    • 12422
                    You're weird man.
                    1991 325iS turbo
                    • jaywood
                      • Jul 2010
                      • 4528
                      LC-1 wideband will be just fine - I've had no issues with mine for a year plus. Get the one you like more. They are both great.
                      You need to PM whodwho before you get MS. He is the one who will sell it to you. Blueapplesoda also sells PNP MS.
                      • Cyrix2k
                        • 593
                        Don't get an LC-1 unless you love replacing widebands
                        Let Me Google That For You (LMGTFY): for all those people who find it more convenient to bother you with their question rather than search it for themselves.
                        1997 540i/6 - stock
                        • Pl3wA
                          • 1589
                          also, which fuel pump would work?
                          walbro 255, I didnt know there were so many
                          gsl392
                          gss342
                          gss315
                          gss317
                          gss340
                          gss341
                          and 60lb injectors? sounds good, ill diefinetaly give whodwho a pm
                          • JayGotti
                            • Jul 2012
                            • 200
                            an oil catch can is basically a can that has lines fed from the valve cover,(bungs/ niples w/e u call it welded in it) to it, when boosting the oil pressure rises and some goes to the can, (that allows pressure under boost to escape your motor and the oil goes into the catch can and then drains back into the block via the line going to the block) os sandwich adapter.
                            • Kvasi
                              • Apr 2011
                              • 1122
                              http://lmgtfy.com/?q=dead+lc-1
                              Havent replaced mine yet, and neither have the 9 friends of mine that has lc-1.
                              http://lmgtfy.com/?q=dead+AEM+UEGO ;)
                              • JayGotti
                                • Jul 2012
                                • 200
                                by o-ring do you mean sleeved?
