Blow through or draw through?
  • agile30
    • 832
    For the mass air flow sensors. What are the main differences with the set ups? Pros? Cons?
    Just reading around and it seems like the tuners sell the blow set ups with their tunes. I have a friend who has an emulator who will tune the stock ecu. But Im not sure if I should go with War/TRM for tech support wise.
    What do you use?
    Originally posted by Good & Tight
    It takes real man to mount a big woman, all you haters are just scared boys.
  • Dj Buttchug
    • Jun 2010
    • 7640
    ideally speaking there are two types of blow through Mafs. Im assuming you arent interested in air flow meters as MAFs are usually more efficient anyways. The two types are hot wire and hot film. Both work essentially the same. The best way imo would be IAT and a map but im not sure if WAR will support that
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • agile30
      • 832
      well lets say the stock maf vs war maf vs trm?
      • Good & Tight
        • Apr 2004
        • 2057
        I'm assuming this is for a 24V engine, the stock maf is good for draw through only not for blow through.
        Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
        ____________________________
        E-mail Panayiotisx2@gmail.com
        Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
        • agile30
          • 832
          Sorry for seeming like a retard but...... your able to use it then for a turbo set up without running into issues or will running it on boost fuck up the flap on the maf / cause retarded readings?
          What did you run on your euro 24v? Yea its going to be a set up on a m52.
          • Good & Tight
            • Apr 2004
            • 2057
            Well the maf has no flap so your good there using the stock one for a draw through (maf in front of turbo).
            My euro was draw through with a recirculating bypass valve, it's a blow off valve but it doesn't blow of to atmosphere, it recirculates back between the maf and turbo.
            Are you just boosting the stock compression engine or adding a MLS and ARP's?
            • agile30
              • 832
              Mls and arp. Plan on running 15psi maybe 18 depending on what tune feels right in that range.
              • Good & Tight
                • Apr 2004
                • 2057
                Then you deff want a blow through set up, contact TRM, they are expert tuners for turbo charging.
