Before I start I have used the search button but was unable to find any info on where exactly would be the best place to tap for my fuel solenoid any help would be greatly appreciated!!!!
Need help with nitrous setup
Tags: None
I would tap into the fuel line personally. Like...before the fuel pressure regulator, that way you are getting a high enough PSI to spray correctly. You should have 2 options for lines if I'm not mistaken. The one going to the fuel rail, and the one going to the cold start injector. -
Thanks man ill give it a try I bought a setup off a buddy of mine and 3 gauges a/f, nitrous, fuel pressure as well as a purge system not bad for $200!!!Comment
+1 on vids, I wanna see this!
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]Comment
What's involved in a nitrous setup? Constant flow into a fuel line and higher flow injectors?The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP)Comment
Most nitrous set ups just run one fuel solenoid to add the extra fuel needed. You can get crazy though and go direct port and have the fuel and nitrous sprayed into the intake runners separatelyComment
