Enginr pinging when i blip the throttle
  • ron1999
    • May 2007
    • 122
    M42 DASC engine,
    all original setup,
    original fuel pump,
    fuel supply has RRFPR provided with the DASC kit
    injectors are 19lb/s from Saab 900 turbo
    this is like this - when i blip the throttle the engine is pinging, if i keep on with open throttle, pinging disappears, but at the first second or so - the engine pings really hard.
    p.s. this happens when the engine is hot-very hot, when the engine is cool, this does not happen or happen a lot less
    what can this be?
    im using my car for drifting, and there this thing happen all the time...
  • horror business
    • Jun 2010
    • 11
    The factory fuel pump may not be cutting it just to start with..
      Pinging is usually from insufficient timing advance.
      • Nick_08
        • 165
        Originally posted by jlevie
        Pinging is usually from TOO MUCH timing advance.
        Fixed ;)
        You are most likely going lean when stabbing the throttle. You can't do much about that with an RRFPR. As your engine gets warmer it requires a little more fuel.
        Pinging is from detonation. Too much timing/ lean mixture or a mix of the two. More fuel will compensate for the timing to an extent.
        -Nick
        • digger
          • Nov 2005
          • 6180
          you sure it's pinging and not some other noise?
          there is very little flow to cause huge pressure and temp needed for pinging by blipping the throttle
          • ADlBOO
            • 335
            If its knock their could be so many things causing it. What octane fuel are you using, how much boost, timing advance?
            I have friends who are EOD bro.
            That's awesome. I have friends who make coffee for a living, but you don't see me rocking out a bunch of lattes
