Originally posted by TC|Photography
View Post
Late model Vert Turbo!
1997 540i/6 - stock
1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
My 8lb tial spring is pretty consistant even on a log manifold.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
getting a little closer.. Just neet to run the vac lines and clean up the engine bay
Untitled by Visions: Photography Tyler Cauley, on Flickr
not true about the injectors, i am running 18lbs of boost, we started with 24lb injectors and was able to reach 15lbs of boost before the injectors where maxed out and it was going lean, i bought 36lb injectors and i do not have any issues, i can run up to 24lbs of boost on these easy, its all about how you tune it!
Installed a aluminum radiator last night
As with most projects once everything is running smoothly shortly after comes the clean up/details.
Painted the heat shields and I repainted the valve cover and filed out the lines and the BMW. Added some reflective heat shield on the charge pipes.
Got some goodies today!
3" stainless exhaust straight through to this beauty.
Finished the exhaust. Full 3" into a Vibrant muffler 3" inlet-dual 3.5" outlet
