Homemade tester with a rubber coupler pvc cap and a valve stem hooked up to an air compressor
Car won't go into boost?
1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
I can't remember I will retest tonight and post my results1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
Originally posted by Pootis View PostI talked with a holset dealer today who rebuilds turbos (flame suit on) and he said he has been rebuilding turbos for 30+ years and he has never balanced a holset and the rebuild is pretty easy (I know obviously something went wrong the first time lol) I am just hoping the exhaust blades are mangled I have looked at the intake blades and they look fine
I've had luck with G-Pop shop with rebuilding turbos, I also had them port and polish the turbine housing.'84 318i M10B18 147- Safari Beige
Yeah I have come to believe that the turbo shaft is slightly bent and therefore causing resistance. I'm going to disassemble the turbo and take the shaft to a turbo specialist locally and have him take a look at it1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
Haha and I did a boost leak test everything held strong no leaking......better get that lube out I guess1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
Did you rebuild it or buy a new one?1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
You warped the head without making any boost? And that's what I'm trying to decide whether to rebuild it or just buy another one I believe I am going to need a new wheel and shaft1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
Yeah got the turbo off today and it is pretty f'd the shaft is completely scoured from the bearings1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
