where do you run your charge piping?
  • redsubdivisions
    • Feb 2011
    • 1762
    I currently have my M20 turbo build at a small standstill due to changing my mind about my intercooling setup. Instead of the water to air setup I originally planned, I have a spare intercooler laying around. Not only is it cheaper, but aside from buying piping, it's free (as opposed to shelling out the additional $500 for a decent WtA setup).
    with that said, I want to figure out how I'm going to run my charge piping. I am getting 2.5" piping and what I am hoping to do is run it under the headlamps with some small modifications to the headlight brackets.
    So...how do you have yours setup? If it's under the headlamps, post a picture!
    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
    2012 Passat TDI - DD Duty
    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
  • MF DOOM
    • Apr 2012
    • 944
    i cut a little on passenger side.
    massage valence
    • TheTacoMan
      • Nov 2011
      • 2308
      I have a similar setup, I had to trim the headlights as well.
      • BMWManiac
        • Dec 2010
        • 1091
        I had to trim my passenger headlight some, not a big deal....but I run both my piping under the headlights...posted pics on my build in the projects sub forum
        1997 Artic Silver M3
        CES GT4094r 651hp/615tq @ 24 psi
        • ColdAsLife
          • Mar 2013
          • 142
          I cut the headlight as well as cut the valence to fit with lots of trial and error.
          • Northern
            I like cupcakes & sh!tboxes
            • 5208
            Same as above.
            Originally posted by priapism
            Originally posted by shameson
            • GunMetalGrey
              • Dec 2010
              • 1499
              I am running a fairly large intercooler (28x18x2.5 I believe...) and have the piping routed underneath the headlights.
              The passenger side elbow fit perfectly under the headlight without modification, and I had to trim out the bottom of the housing on the drivers side under the high beam to get that side to fit properly. The valance required a fair amount of cutting, and making new upper mounting tabs.
              I will see if I can dig up some pictures, or take some.
              • BMWManiac
                • Dec 2010
                • 1091
                We did cut the valence a fair amount as well, but you can't see it once the bumper is mounted
                • einstein57
                  • Jun 2007
                  • 10780
                  www.gecoils.com
                  • hyperE30
                    • Sep 2009
                    • 2202
                    Same as posted above, under the headlights, I did have to cut the valance and trim a good portion of the lights, running 3"..
                    HyperWerkz
                    89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
                    " enjoy the show "
                    • redsubdivisions
                      • Feb 2011
                      • 1762
                      Bumping this thread for some insight:
                      As I am mounting up the intercooler, it seems the condenser hardlines are keeping the intercooler from sitting completely flush on one side. This is preventing me from attaching the front valance fully without serious modification. Anyone else run into this same issue?
                      • redsubdivisions
                        • Feb 2011
                        • 1762
                        einstein57 pretty much solved my issue with his link post. Looks like I will be getting a different intercooler.
                        • BMWManiac
                          • Dec 2010
                          • 1091
                          Check out my build thread....we notched the support so that we could run the condensor lines.....worked like a charm!
                          • redsubdivisions
                            • Feb 2011
                            • 1762
                            Checked it out. Definitely gave me a good idea for the future should I need to modify it. I went after an intercooler that would allow more airflow to it behind the kidney grills, as well as the ability to retain the stock oil cooler location. Before I worked on my E30, I never got the freon vacuumed out so I'm working with a pressurized system until I can get the chance to drive it to my work and refill as necessary.
