Hey all,
I am new to the forum, but have eagerly begun planning my turbo build for my new to me 325i. I plan on using the car as a street-able track car mostly for road racing.
I am starting to research a turbo build and based on my calculations for required mass flow rate and pressure ratio I found a turbo sized around a GT3076R or GTX3076R would be good for about 350whp for my m20b25. I plan on building a custom twin scroll manifold and have heard good things about Borg Warner turbos in the past from my subaru days. I found that the EFR 7064 with a .92 A/R T4 twin scroll turbine housing has a similar compressor map to the GT30R but has an internal wastegate and BOV. The reason this is attractive to me is that it would make packaging a bit easier and may end up reducing the cost of my turbo build since I wouldn't have to buy 2 wastegates. This series of turbo also has the oil restrictor built into the cartridge so that is one less thing to worry about.
Does anyone have any experience with the Borg Warner EFR turbos or the EFR 7064 specifically?
Thanks,
Alex
Thanks,
Alex
