E30 M30 Turbo Build Thread...
    Originally posted by nybimmers View Post
    Because stock works fine.
    Got it! If it ain't broke don't fix it. Unless it's an eBay part, then you should sell it to Des.
    Click here to leave me feedback on our transactions. :p
      My guess is that you'll need a bigger fan, but it won't hurt to try the stock one for a while.
        I doubt it, was running stock fan and oem radiator before, engine would stay a little above 1/4. I will eventually run the fan off ms2 with hi/lo speeds.
          Finished the charge pipe, hood won't close lol, going to either cut the hood or shim it if possible.
            Update time. I am rerouting the charge piping behind the intake along the firewall so the hood should close.
            Here i cut the grills around the intercooler bracing, i'm going to try to piece on whatever i can of the valence.
            Welded up the bracket for the ls1 ignition coils, added a bracket on each side, and welded the ls1 bracket to the m30 afm bracket so it bolts to the valve cover.
            And here is the finished product.
            All thats left is wiring up the m30 auto tps, the innovate lc-2, run all the vacuum lines, weld the exhaust, and tune.
              You thought about mod'ing the manifold,Alpina B10 style:
              292rwhp E30 :D
                Yeah, just haven't gotten around to it. I will eventually, gonna pick up a second manifold.
                  Lovin the progress man.
                  Keep it up!
                  -Greg
                  90 325isT - 12.2 @ 120ish - Dyno Results
                  b18c5 EG Coupέ - 13.5 @ 100ish - Dyno Results
                    Ok ok, been a long time since i updated. She's Alive!!!!
                    Pulls like a freight train, boost is insane.
                    In the process of installing the stage 5 clutch now, stock would slip at about 8 psi. Still working on tuning in. Also tracking down an oil leak that covered the entire underside of the car.
                    But boy is she fun. This is going to be an abusive relationship for sure...
                      That first picture is screwing with me - it almost looks like a painting.
                      Either way, nice build! Congrats on getting it on the street. Hope you budgeted new rear tires!
                        Congrats on getting it running..! Whats your timing map look like and are you running E85?
                        Wait till you get the new clutch in a feel 15psi, lol Be safe dude.
                        Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                        ____________________________
                        E-mail Panayiotisx2@gmail.com
                        Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                          Here's what i'm working with.... Running 93
                          Any help would be greatly appreciated as i'm still trying to figire this stuff out lol
                            I would pull some timing from between 120-140 kpa from 4k to 5k. It's were peak torque is and cylinder pressure is high.
                            Check your spark plugs for detonation, also NGK B7ES plugs will work great.
                            Keep your AFR's in the mid 11's
                            Your timing at idle should have all the same values, from 800-1000 rpm in the lower left were the map dot is while the car is running. This will smooth out your idle.
                            Have you tried the auto tune feature?
                              I did try the auto tune feature, it helped a lot.
                              I went with bkr7e plugs
                              I'll play with it some more, haven't had any signs of detonation.
                              The car idles as smooth as glass lol.
                              Question, i have my afr's in the 12-13 range under 100kpa, above that is where i should be in mid 11's, right? And would i do that by changing the afr table and using the afr target?
                                Correct about the afr range. Set up your AFR table for 11.5 above 100kpa, disable the 02 sensor correction, turn on auto tune go for a pull, easing into boost keeping any eye on the afr's. Hit "Save on ECU" do another pull and repeat.
                                It will even out your fuel ve table stabilize the afrs under boost.
                                How difficult was getting the COP set up running? I'm still running the EDIS with a coil pack and would like to convert to COP.
