M20 tcd s2 kit
  • eurochrome
    • Apr 2013
    • 26
    M20 tcd s2 kit
    Hello I'm new on e30's but i like it so much, and buy one to play around, i have turbo kit forn TCD with water to. Air cooler. And I'm intetested and get a blow off how can i do that
    also i need wasted spark if some one has a set up for m20 let me know
  • Danny915
    • Sep 2012
    • 200
    As for wasted spark, the module from the supercharged regals work. Do you have a standalone system such as megasquirt?
    Sent from my SGH-M919 using Tapatalk
    • eurochrome
      • Apr 2013
      • 26
      No I'm still thinking if i go for vems with harness
      or megasquirt
      • Danny915
        • Sep 2012
        • 200
        Whodwho stands by his product, I know ny working with FLG and his car, I will be buying his megasquirt when I'm finished gathering turbo parts
        • eurochrome
          • Apr 2013
          • 26
          I already talk to him but he got some boards coming
          • marco 325 a
            • May 2011
            • 83
            You can't go wrong with whodwho megasquit great guy no bullshit
            • Q5Quint
              • Jan 2005
              • 725
              Been running a whodwho for a year or so- working great and took about 30 minutes to install.
              10/10 would squirt again
              • Atlant
                • Feb 2012
                • 63
                The TCD kit uses a (Bypass valve/Recirculating Valve) instead of a blow off valve. It would be a waist to use a blow off valve in your kit because it is designed for a recirculating valve.
                • Q5Quint
                  • Jan 2005
                  • 725
                  http://forums.pelicanparts.com/911-9...n-bov-lag.html
                  Everyone knows that just letting your bov vent to the atmosphere is a waste. However most cars come stock with bypass type valves because of the maf sensor used for fueling, which is how the TCD kit is still setup I believe.
                  With manifold pressure sensing ecu systems there is no reason to do this, other than keeping the turbo spooled a bit better and not having that loud chirpy chirp of a atmosphere vented valve.
                  • eurochrome
                    • Apr 2013
                    • 26
                    You right but I kinda love the whooosh sound from the atmosfera bov
                    Maybe if I just get a new turbo ball bearing I can get better whistle sound ?
