MLS Headgasket Question
  • speedracer 2002
    • Dec 2013
    • 359
    Well I'm turning up the bewst on the car tomorrow to 18 lbs hoping to make 450+ on stock internal m20 but it'll probably blow up first or my headgasket will haha. But anyways depending on how things go I'll probably be building another motor. I've seen a few turbo builds were people are putting MLS headgasket on block that haven't been resurfaced/machined. I always thought they won't seat right and leak/etc and never really settle correctly causing problems and need a smooth even surface. Is this true? Or anyone have experience other wise? My headgasket will probably blow before I hit what I want anyways lol.
    For viewing pleasure. Car has wasted spark
  • sayed ali
    • 762
    True, but I think you'll need more boost to reach +450 especially on a stock motor
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
    • TheTacoMan
      • Nov 2011
      • 2308
      If you still have the stock cam Id imagine 18psi on 91oct to be around 360-400whp with a decent tune.
      • speedracer 2002
        • Dec 2013
        • 359
        Cars on e85 right now. Made 320 on 12lbs so probably 18-20 will make it happen. So block does need to be machined for MLS gasket
        • bobross
          • Jul 2005
          • 753
          I did not machine the block, only the head. + copper spray
          -Greg
          90 325isT - 12.2 @ 120ish - Dyno Results
          b18c5 EG Coupέ - 13.5 @ 100ish - Dyno Results
          • dougie30
            • Apr 2012
            • 1708
            copper spray should not be used on a metal gasket
            M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
