M20 Turbo Clutch
  • speedracer 2002
    • Dec 2013
    • 359
    M20 Turbo Clutch
    Looking at what you guys recommend for a m20 turbo clutch. Not looking to spend tons of cash. Drivability isn't a huge issue but still a concern. Car made 383 and has more still in it but clutch wouldn't hold.
  • jaywood
    • Jul 2010
    • 4528
    F1 racing. Ebay.
    • 808e30325i
      • 537
      ^ x2
      • speedracer 2002
        • Dec 2013
        • 359
        part number? Everything i'm seeing is only good for 280whp.
        • TheTacoMan
          • Nov 2011
          • 2308
          Spec Stage three is what Im running, Although I hear Tcds is better.
          • IronFreak
            • Dec 2012
            • 3702
            I'm going to be running a stage 3 gripforce setup for an e36m3 on my seta. it'll all bolt up, just need and m50 starter. bigger/stronger clutches available with that route.
            If you don;t want to go that route I've heard good things about tcd kevlar clutch and Spec like Taco mentioned.
            Instagram @rebellionforge
            • sayed ali
              • 762
              TCD stage 2 clutch seems to be very good for your goal ..
              M20B28 Turbo
              My Build Thread
              http://www.r3vlimited.com/board/showthread.php?t=255839
              • codrum
                • Jan 2011
                • 279
                Agree the the Spec stage 3. I've been running it on 15psi for the last couple of years - no issues. I had a similarly rated Competition Clutch in an older car and hated how twitchy it was. Very happy with the Spec.
                • Jaxx_
                  • Dec 2009
                  • 1880
                  I have a spec stage 3 in my m10 and I love it. It's probably a bit much for daily use, but you can still go to the grocery store without much fuss. I know that doesn't matter much to you, but it's not entirely "unstreetable"
                  • kamotors
                    • Nov 2007
                    • 7102
                    spec stage 3 is awesome
                    7speedshop.com
                    • Q5Quint
                      • Jan 2005
                      • 725
                      I have a tcd stage uno and it is stock drivability with def more clamping.
                      You prolly want the stage dos.
                      • einstein57
                        • Jun 2007
                        • 10780
                        Thats my current setup. Supposed to be rated at 450 ft lbs
                        www.gecoils.com
                        • LowR3V'in
                          • 4209
                          ^So you can run an m50 setup just need the starter?
                          bigger size flywheel?
                          I had the m20 stage1 it was buttery smooth but slipped at 380tq.
                          • IronFreak
                            • Dec 2012
                            • 3702
                            Correct. you can run a complete e36 setup on the m20, just need the m50 starter to line up correctly with the ring gear.
                            • speedracer 2002
                              • Dec 2013
                              • 359
                              whats the part # for m20 spec stage 3 clutch? finding different numbers seeing what you guys have.
