Has anyone setup an electric gear driven oil pump for supplying the oil to the turbo?
Basically, I'm lazy and have a journal bearing turbo. I don't want to have to worry about setting up a turbo timer for the engine and remember to leave my car out of gear with the eBrake on (isn't the best on hills) and making sure the turbine spins down fully before the engine is shut down. Normally I just toss it in reverse and put the eBrake on and shut off the car.
Ideally what I would like to do is either supply all of the oil for the turbo from an electric gear driven pump or have a method to switch over to the electric pump when the car is shut off. That way I can set the turbo timer to run the pump and supply the correct pressure and flow while the engine is shut off so that the turbine can spin down safely and not damage the journal bearing.
I've been watching a small company for years in California who has done extensive modifications to Kawasaki and BMW motorcycles and they appear to have a solution for their turbo bikes but I can't seem to find anyone who has done something like this for cars.
