As far as damaging the motor it is not a huge deal. When the crank is swimming in oil the motor has to work harder (picture running underwater as opposed to running out of water). So you may see it struggle to start but as soon as the pump starts pumping the oil level should drop and the Accusump/Turbo Oiler will take it's oil and you should be good.
Electric gear driven oil pump for turbo oiling post shut down instead of turbo timer
That's what I figured. I know your engineers probably figured out that most turbo systems only need a quart of oil for lubrication/cooldown, but I'm a paranoid dude and would rather have three quarts running through. Sure, the oil changes would be more expensive, but oil is pretty cheap compared to a nice turbo.Comment
