formula?
  • der affe
    Technical
    • Dec 2005
    • 8452
    formula?
    anyone know the formula for finding displacement for a 6 cyl? i know that a 4 cyl is BORExBORExSTROKEx.0031416 (or PI), but what is it for a 6 cyl?
    greg
  • Axxe
    • Aug 2004
    • 3355
    displacement = (bore ^ 2) * (stroke) * (pi) * (number of cylinders)
    pi = 3.14
    Keep it slideways!!
    • der affe
      Technical
      • Dec 2005
      • 8452
      (bore ^ 2) = bore x bore right?
      • madjurgen
        • May 2005
        • 1203
        pi = 3.14
        wrong
        bore is the diameter, you need to divide all that by 4
        make sure your units are in centimeters
        As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
        You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
        • der affe
          Technical
          • Dec 2005
          • 8452
          if i am looking for a 6 cyl whay do i devide it by 4? do you mean 6?
          • madjurgen
            • May 2005
            • 1203
            no
            bore = d = diameter of cylinder
            r = d/2
            when squared
            r^2 = d^2/4
            come on people, simple math here
            cross-sectional area of one cylinder*length of stroke*number of cylinders=total volume
            • der affe
              Technical
              • Dec 2005
              • 8452
              thanks, i actually figured it out for myself. just did BORE X BORE X STROKE X PI....DIVIDED BY 4 TO GET THE DISPLACMENT OF A SINGLE CYL THEN X 6 TO GET THE DISPLACEMENT OF A 6 CYL
              greg
