Recirculating bov help
  • hokejka
    • Jun 2014
    • 271
    Im a little confused. I am putting together an m50 turbo in my e30. I don't understand how to make the recirculating BOV in my blow through setup work. I am limited in space and want to fit a large cone filter in that little corner (I'm running top mount)
    Premier Turbo, Rotary & Import Performance Products TiAL QR 50mm Recirculating Blow Off Valve BOV [Tial QR] - This item is normally in stock & ships within 1-72 hours.TiAL QR Recirculating Blow Off / bypass Valve (BOV) is a recirculated version of the TiAL Q BOV with the added ability to recirculate the air back to the intake. Uses the same mounting v-band flange as the all the
    I got this bad boy.
    Do I run a one inch pipe across my engine from the BOV to right before the turbo?
    If so, what kind of piping do I use to connect the one inch pipe running from the BOV to before my turbo?
    From what I know I should have Cone filter -> MAF -> Recirculated air from BOV -> turbo. right?
    Thanks
  • TheTacoMan
    • Nov 2011
    • 2308
    You want the the bpv blowing into your maf, mafs measure the amount of air going in and needs to account for the air from the blow off vavle if im not mistaken.
    • jntar
      • 459
      I got this bad boy.
      Do I run a one inch pipe across my engine from the BOV to right before the turbo? Yes or anywhere post maf sensor but pre-turbo
      If so, what kind of piping do I use to connect the one inch pipe running from the BOV to before my turbo? 1" hose from any parts store should be find. It's not going to have too much pressure.
      From what I know I should have Cone filter -> MAF -> Recirculated air from BOV -> turbo. right? Yes
      Thanks
      M42 turbo build.
      http://www.r3vlimited.com/board/showthread.php?t=301330
      • jntar
        • 459
        No, because the air is already metered.
        M42 turbo build.
        • speedracer 2002
          • Dec 2013
          • 359
          Yep! Post maf, pre turbo is were you want it.
          • hokejka
            • Jun 2014
            • 271
            Thanks for the responses. I can't find short "2.5" intercooler piping with a 1 inch nipple online? Any chance you guys know where to get one or do I have to get one welded?
            • jntar
              • 459
              Your source for Intercooler Pipe Fabrication Parts
              Bought all my piping stuff there.
              M42 turbo build.
              • hokejka
                • Jun 2014
                • 271
                YTM! they have the exact one i nee. thanks so much. Ill have build thread up in the next week!
                • jeffnhiscars
                  • Jun 2011
                  • 6010
                  http://siliconeintakes.com
                  I browsed that site for half an hour. Nice collection of widgets
                  Alice the Time Capsule
