turbo oil return into B**ch tube?
  • Cayoncrusier93
    • Jan 2013
    • 204
    Has anyone drained their turbo return into their bitch tube? Seems easier than tapping the oil pan, and I think it would work fine. Anyone have any info on this?
  • TheTacoMan
    • Nov 2011
    • 2308
    I can't see it working, turbo is too far away to drain properly.
    • Cayoncrusier93
      • Jan 2013
      • 204
      geez I forgot the oil return tube is on the other side of the engine. :loco: I need more coffee!! Thanks Taco
      • TheTacoMan
        • Nov 2011
        • 2308
        There is a company that makes oiless turbo that get good reviews, it will be the next turbo I go with on my car.
        Comp Turbo manufactures high performance turbochargers, wastegates, blow-off valves, and components engineered for proven power, fast spool, and lasting reliability.
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          No options that work well are easier than tapping the block or pan.
          I feel like the cleanest option is to drill and tap your block for a -10AN or -12AN fitting and thread it in with some sealant. Best spot I've seen to do this is right behind the AC bracket, which usually ends up directly below the drain from the turbo and only needs like a 1.5ft straight line.
          Originally posted by priapism
          Originally posted by shameson
          • dirtie30
            • Jun 2013
            • 28
            http://compturbo.com/turbochargers
            I'm running a Comp Triplex 6262 on my Audi. I absolutely love it.
            I almost went with one of their oil-less turbos. I would have too if I hadn't talked to a few people that were running them. Apparently they were horrendously laggy, they were still working out what type of grease to run in the CHRAs to make them spool like a oil fed turbo. Now, that was something like 3 years ago, so they very easily could have it all sorted out.
            Precision.... ohhhhhh do I hate Precision turbos. Don't support that shit company /rant.
