Toothed flywheel
  • Jeff Schaadt
    • Jul 2013
    • 141
    Toothed flywheel
    Running the 325E bottom end with the "I" head, and wiring harness, will I need the toothed flywheel from the "I" motor and will I still run the CPS and reference sensor on the "E" transmission?
    Thanks
    WMMFT Racing/Condor SpeedShop/BimmerHeads
  • E30NJ
    • Aug 2013
    • 921
    • kistler#7
      • Jun 2013
      • 186
      You'll have better luck searching "harmonic balancer" when your cruising the classifieds. And IIRC there was a free one in an m20 part out thread recently
      m20b27 Turbo. Hx35. Twinscroll Mani. MS1. 42lbers
      http://www.r3vlimited.com/board/showthread.php?t=338818
      • IronFreak
        • Dec 2012
        • 3702
        Are you talking about the timing gear for the hall or VR sensor on the front of the motor? Flywheel is in the back.
        Flywheel wise it has more to do with the starter, I have a seta I swapped motor that I'll be running an e36 sized flywheel with a m50 starter.
        Now.....if this is for the timing gear, it depends on what ecu you're running.
        Instagram @rebellionforge
        • Jeff Schaadt
          • Jul 2013
          • 141
          Ummmmm, pulling head out of ass, yes, harmonic balancer/toothy sensor disc..... That's why I prefer to drive vs. wrench.
          • Jeff Schaadt
            • Jul 2013
            • 141
            Megasquirt 2 ECU.
            • IronFreak
              • Dec 2012
              • 3702
              Did you buy it from DIYAutoTune or whodawho?
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                Are they different?
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                • IronFreak
                  • Dec 2012
                  • 3702
                  They can be depending on how you set stuff up. pretty sure whodwho has all his stuff ready to rock so you want to go off of what he recommends. There are different types of trigger wheels you can use for aftermarket applications, diyautotune sells a few. it's all in the programming.
                  whodwho took out the guess work, real pnp, you just have to play in his parameters.
                  • LJ851
                    • 7918
                    The megasquirt needs a missing tooth/teeth type of setup like the toothed front balancer on M20B25 which is 60-2.
                    I'm pretty sure the toothed flywheels don't have missing teeth which is why they have a second reference sensor but i could be wrong. If i'm wrong and the flywheel does have a missing tooth arrangement that is supported by the MS then you should be able to use it.
                    Lorin
                    The M30 is God's engine.
                    • Jeff Schaadt
                      • Jul 2013
                      • 141
                      Alright , Thanks for the replies.......got a "I" setup on the way........MS is from DIY.
                      • IronFreak
                        • Dec 2012
                        • 3702
                        Did you go the pnp from them for the bosch 55 pin connector?
                        • GunMetalGrey
                          • Dec 2010
                          • 1499
                          I think that's the best name I have heard for it yet lol
                          • Jeff Schaadt
                            • Jul 2013
                            • 141
                            Yes, PNP, set up for the. "I" harness.
