42lb injectors for 350hp?
  • CrazyPrime
    • Jun 2014
    • 286
    Exactly what the title says will 42lb's be sufficient for 350whp?
  • ak-
    • 12422
    What motor?
    My 2.7L m20 is making that exact power right now on 42lbs till I fix a few things, but can't remember at what %.
    Oh yeah, don't cheap out on injectors. One of the big no-no's in F/I.
    1991 325iS turbo
    • CrazyPrime
      • Jun 2014
      • 286
      M20B25 stock except for oring and new stock HG
      • E30SPDFRK
        • 5716
        Will be fine unless you plan on running e85, in which case they'd be maxed out.
        Byron
        Leichtbau
        • sayed ali
          • 762
          guess they'll be fine but sure on high % .. which is not good for future plans :)
          M20B28 Turbo
          My Build Thread
          http://www.r3vlimited.com/board/showthread.php?t=255839
          • ForcedFirebird
            • Feb 2007
            • 8300
            With pump gas, yes (not e85). I have found on 6cyl turbo engines, you add a "0" at the end of the injector lb/hr rating and that's about what HP you can get at the wheels. Have used 36lb/hr injectors often and have seen them go as high as 357whp ~90% duty.
            john@m20guru.com
            Links:
            • CrazyPrime
              • Jun 2014
              • 286
              Is anybody using 42lb'ers and making 350whp and what % are they running? Just making sure I don't hit 100% duty..
              • ForcedFirebird
                • Feb 2007
                • 8300
                If 36lb/hr can do 357whp at <90%, then you are plenty safe with 42's ;)
                john@m20guru.com
                Links:
