M20 Turbo build questions
  • beggs
    • Oct 2015
    • 52
    So I'm doing a turbo build on a 1987 325is. My power goal is around 400-500 and this will be my daily. The products I'm going to buy are:
    VAC - M20 'Pro Series' Turbo Build Kit
    and the Kamotors Canyon Crusher Kit
    For a cams, would you reccommend replacing at all? I had my eye on the Vac motorsports turbo cam.: https://store.vacmotorsports.com/bmw...px?Thread=True
    And another question is would you recommend me get a shop to o-ring the block? I wasn't planning on it but if this is a MUST then I will.
    If you recommend ANY products please tell me! Anything helps! Thanks.
  • ak-
    • 12422
    Is your power goal 500hp in an e30 or 500hp in an m20 powered e30?
    For the money you're about to drop, I would swap in a stock m52 and turbo that to hit 500hp casually than gamble the m20 like that.
    You're still thousands away from getting it running even with the plan you listed.
    If you're stuck on the m20, I reccomend getting your head built with Bimmerheads along with an O-ring'd block which they can take care of as well.
    Source your own parts to save the expense of kits you're thinking about buying.
    1991 325iS turbo
    • beggs
      • Oct 2015
      • 52
      I'd like to stick to the M20. If I bought something similar to this it would be able to support my power goals without a hiccup?
      BimmerHeads is a full-service engine builder, engine machine shop, and parts house specializing in Classic BMW vehicles.
      Anything else you recommend on doing?
      Thanks for the info!
      • nomansland92
        • 1657
        Personally I would suggest the MLS over any o ring job. If the MLS is installed correctly it won't leak and it will all the power you can throw at it. You might want to consider a forged crank, just a suggestion though. Also e85 or meth injection is something to consider unless you just want a bigger turbo with more lag. And of course a stand alone ecu is a must.
        Good luck
        IX being restored here
        Ix turbo build here
        • Dylanhat
          • May 2013
          • 557
          I'd personally run a Bimmerheads regrind or billet cam.
          Neue Motorsports: http://www.neuemotorsports.com/
          Instagram: https://instagram.com/neuemotorsports/
          • beggs
            • Oct 2015
            • 52
            So I've done research and figured out what I want.
            I'm really wanting the best quality parts for a daily. I'm not going to do any special fuels like E85 or Methanol Injection yet. For this I'm trying to keep it under 20k with the car being priced at 4500. If you recommend anything please say so! Anything Helps!
            Below are the parts list:
            Canyon CrusherTurbo Kit By Kamotors
            M20 performance engine by Vac Motorsports
            Manual boost controller by Grimmspeed
            Bosch Spark plugs
            K&N Air Intake
            Fuel pump
            Magnaflow exhaust(Maybe, might ask custom fabricators to straight pipe to save 600 bucks)
            Tune by Cryotune
            Custom exhaust work
            AEM AFR gauge
            TRU Boost gauge
            AEM EGT Gauge
            Wilwood Stage 2 Brakes
            • LowR3V'in
              • 4209
              500hp in a daily it'll be a short life.
              • beggs
                • Oct 2015
                • 52
                Well since winter is coming I'll do a conservative tune low 400's or high 300's, then once summer hits I'll do higher.
                • BMWManiac
                  • Dec 2010
                  • 1091
                  I daily the M3 with 650....been boosted since 2005
                  1997 Artic Silver M3
                  CES GT4094r 651hp/615tq @ 24 psi
                  • BMWManiac
                    • Dec 2010
                    • 1091
                    Good luck
                    And I could not respectfully disagree with you more.....I've had two different shops (TRM being 1 of them) and myself install a MLS headgasket and all 3 x times, they eventually leaked......
                    Now, the motors in both my BMWs have o-ring'd blocks......that is a must for FI in my opinion.
                    • ak-
                      • 12422
                      Bosch Spark plugs
                      K&N Air Intake
                      Fuel pump
                      Tune by Cryotune
                      Custom exhaust work
                      AEM AFR gauge
                      TRU Boost gauge
                      AEM EGT Gauge
                      With a $15k budget I would ditch the overpriced VAC built M20 and have Bimmerheads built it with the same, if not better, internal components and add a half liter at the same time.
                      Have you seen FLG's turbo m20? LOL.
                      true chainz
                      Your M3 wasn't a single cam 170hp motor to start with though. 650 is casual power nowadays for turbo 24v BMW motors.
                      I agree with this however. Same story with 2 close friends.
                      1991 325iS turbo
                      • nomansland92
                        • 1657
                        Did you take the rivits out of them and coat each layer with copper spray. That's they way my builder tought me at least, been holding so far. But whenever gets the job done works you can't complain haha
                        Ix turbo build here
                        • BMWManiac
                          • Dec 2010
                          • 1091
                          Nope, but I use copper spray on my e30 as well. Exactly, if it has worked for you, great, but I've given MLS too many opportunities
                          • OOMPH!
                            • 3487
                            I agree, stay away from VAC. Everything and anything to do with VAC, stay away.
