Weird Fuel Cut and More...
  • squidmaster
    • Aug 2011
    • 2666
    You're still getting the fuel cut? Is the new CPS in too?
    • Chris Spiegl
      • Aug 2016
      • 155
      New CPS comes in saturday. The fuel cut is still there. The car is running horribly. It is super jumpy. the afrs under load are 9,5-10. (before boost)
      1987 325is 2.8L Stroker Turbo "Little Pickle aka The Green Turbo Sled"
      • Chris Spiegl
        • Aug 2016
        • 155
        CPS gap was < 0.5mm. I added a washer and made the gap 0.1mm. At the ecu, the CPS was reading 511 ohms. I also cleaned it.(covered in grime)
        Changed turbo to manifold gasket from composite that came with in to a metal gasket.
        New TPS will be in tomorrow.
        Thanks yall
        • Chris Spiegl
          • Aug 2016
          • 155
          New TPS is installed.
          Will do a test drive when I have time.
          • e30onBBSs
            • Dec 2014
            • 1347
            update?
            BMW tech
            Umass Amherst
            05 wrx sti
            • Chris Spiegl
              • Aug 2016
              • 155
              Originally posted by e30onBBSs
              update?
              Went with a megasquirt ecu and am working on geting that up and running
