Early model fuel pump upgrade options
  • E30-Ellerman
    • Oct 2015
    • 212
    I apologize for posting this but I haven't been able to find a straight answer.
    Basically, just in the process of building my turbo e30 (m20b25) and it's an early model car with the dual fuel pump setup.
    I'm trying to do everything the right way for reliability, longevity and good power and along with that would be my fuel issue. I'm not sure if I am able to just dump in a walboro 255 fuel pump in the tank and away I go or what I need to do to get a larger fuel pump in there. Aim is to start at about 10psi and go up from there. I have ARP head studs, new head gasket and will be running an h1c turbo with megasquirt plug n play standalone.
    Also, I've read here that the early model setup is actually a bit more reliable than the later model and that people have ran up to 14 psi on the stock pumps without issues... Anyone with first hand experience with boosted early model's, would really appreciate any assistance.
    Thank you kindly
    2016 F-150
    1987 Royalblau 325es B25 turbocharged
    Build thread here: http://www.r3vlimited.com/board/showthread.php?t=405594
  • Kepes
    • Feb 2017
    • 1
    I'm building an M20 turbo to run around 15psi in a PFL setup.
    I'm going to keep the stock in tank pump and replace the external pump with a Bosch 044.
    This setup is easy and more than enough provided your transfer/in-tank pump is functional. This may not be the best way but from my research it will work well.
    • E30-Ellerman
      • Oct 2015
      • 212
      That is exactly where I want to be at for boost.
      Thank you!! I'll likely do the same as you.
      2016 F-150
      • e30davie
        • Apr 2016
        • 1788
        Just have to make sure that the internal pump has high enough flow to keep up with the chosen external pump (044 in this case). Probably will, but you dont to starve your bosch 044.
        Last time i designed a fuel sysetm for a ca18det ae86, we had a high flow intank lift pump (pierbirg i think the brand was) and then a bosch 044 external pump. the pierbirg supplied more flow than the bosch but at a lower pressure. The bosch pumps really do not like sucking fuel, they love pressure at their inlet, this will keep them silent (or close to) during operation. I ran a bosch external pump without a lift pump for a while and it did not like it, very noisy.
        • gotaloveRWD
          • Jul 2011
          • 708
          I'm running a walbro 255 in tank and bosch 044 external
          i hope they will function well together
          IG- nv_e30
          • E30-Ellerman
            • Oct 2015
            • 212
            Post up results, thinking I'll need to upgrade my pumps!
            Thanks
            2016 F-150
            • SLEEPYDUB
              • 658
              Im going to try to fit a Walbro 450 in the tank. Wish me luck, because its going to be nearly impossible
              - AXIS POWERS - 2JZ E30 Build
              Current Project - 87 325is 2JZ Swapped with M4 DCT
              • E30-Ellerman
                • Oct 2015
                • 212
                Haha. I'm doing a 300lph Bosch in line pump. Hoping it will work ok. Changing the pump in the tank is pricey and I'm not wanting to go through converting to a single fuel pump... yet.
                2016 F-150
                • Good & Tight
                  • Apr 2004
                  • 2057
                  It will work. Just make sure you purchase an authentic 044 pump and not the cheaper knock off ones.
                  Adding an adjustable fuel pressure regulator would make a big difference also.
                  Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                  ____________________________
                  E-mail Panayiotisx2@gmail.com
                  Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                  • SLEEPYDUB
                    • 658
                    Walbro 450 fits in tank with slight modification. One pump to rule them all. Just run 3/8ths fuel line and you're good for as much power as you want really
                    Sent from my SAMSUNG-SM-G935A using Tapatalk
                    • m3boost
                      • Oct 2005
                      • 110
                      Do you have pics of the modification required? I remember replacing the oem intank with a 255 and it was atight fit...But I'll be going the e85 route in the near future and would like to use a 450 fuel pump
                      88 e30/s50 gt35r turbo m3
                      96 gt4094r turbo m3
                      452 rwhp, 455 rwtq at 14 psi 91 octane
                      681 rwhp, 684 rwtq at 25 psi E65
                      • LowR3V'in
                        • 4209
                        is the 450 any louder than the 255?
                        • SLEEPYDUB
                          • 658
                          This should give you a rough idea
                          • SLEEPYDUB
                            • 658
                            No it's super quiet
                            • E30-Ellerman
                              • Oct 2015
                              • 212
                              Just thought I'd update my personal experience post keeping the stock in tank pump and changing the inline pump to the 300lph Bosch set up.
                              Have been running 11psi boost for about 500 miles on the set up and no issues at all. Getting a dyno tune on May 5th so should get a better idea of how the fuel pump is working but I don't expect any issues at all. Changing the inline pump to a bigger one was a simple and seems to be an effective way to solve any issues or concerns regarding the dual pump set up.
                              2016 F-150
