M20 turbo fuel supply
  • MisterMiniS
    • 397
    I know this general question has been brought up 8 million times, but I'd appreciate feedback on what has worked well and what you would suggest.
    M20
    GT3071R
    15psi max
    60#
    MS2
    What will be more reliable; 255 in the tank, or keep the in-tank stock and add a Bosch 044 in-line? If you say 255 in the tank, has anyone had better luck with one vendor over the other? Say TRE's 255 vs CATuned's 255?
    Thanks!
    1989 325i Alpine White
    69 STX
  • MisterMiniS
    • 397
    Found some really solid info on the topic comparing 4 options.
    69 STX
    • cleanasse30
      • Jan 2014
      • 436
      I'm still running the stock pump...
      haven't had issues yet but I have a 255 pump sitting around waiting for me to stop being lazy...
      2.7i Stroker Turbo Build Thread
      90 325i | 95 Miata
      • downforce22
        • Aug 2009
        • 3192
        im running a walbro 255 external, but my car is an 85 production, not sure if it also has the internal pump or not. only at 6 psi at the moment
        • MisterMiniS
          • 397
          Looks like someone on the facebook page cleared this up.
          "Either center or offset inlet only slightly changes where the inlet is on the bottom of the tank. Won't make a difference"
          Centered is 11140
          Offset is 11141
          69 STX
