boosted OBD1 s52 vacuum questions
  • Dagamus(NM)
    • 618
    Hi all, I have been slowly building up the s52 from my old M Coupe to go into my white MT2 vert.
    I have most of everything assembled and have questions about the vacuum lines.
    Fuel pressure regulator on the s50 rail, do I just connect it to the nipple on the intake manifold?
    charcoal cannister line to??? I assume this should be on a line that only sees vacuum or atmospheric. I know there is a purge valve on the m20 and the s50 seems to have this as well but the s52 has something different. Confused about this.
    Brake booster line needs a check valve I believe, any in particular I should look at using?
    I assume I will have a few more questions as I progress but this is good for now.
    Gun control means using both hands
    Sex, Drugs, Rock 'n roll. Pick two.
  • haaken675
    • Sep 2016
    • 601
    As far as i can tell, the FPR should go directly to the small vacuum port on the underside of the intake manifold towards the back. I would forgo the charcoal canister entirely.
    I wasn't aware that there was any kind of check valve in line with the brake booster as I don't remember seeing one when I removed the old brake booster when I did my m52 swap. Also, what are you planning on doing for blow off valve vacuum, boost gauge vacuum, and MAP? I drilled and tapped my manifold for 1/8th npt fittings, and it seemed to work perfectly.
    • Dagamus(NM)
      • 618
      My manifold has several added ports for those. I know those all need to read the pressure from the manifold.
      Just trying to figure out these ones.
      Does the FPR not need negative pressure? Same with the booster?
      • haaken675
        • Sep 2016
        • 601
        If by negative pressure, you mean vacuum, then yes the FPR definitely needs vacuum. If you instead meant positive pressure under boost, that's actually a good question. I'm not sure what happens to that under boost.
        • haaken675
          • Sep 2016
          • 601
          From searching around (https://www.bimmerforums.com/forum/s...d-SAP-Solenoid) it looks like the only check valve needed would be for the brake booster and charcoal canister if you really feel inclined to run that...
          • Dagamus(NM)
            • 618
            Thank you sir. That is exactly what I needed to know.
