turbo e30
  • charger5205
    • Feb 2007
    • 10
    turbo e30
    i have a 91 325i and i wanna turbo it. i wana know wat would have to be changed and what would be the chances of it blowing somthing.
  • Erick
    Official R3V Drifter
    • 11169
    Oh boy.
    Yeah... you have a lot to learn. There are different applications for turbocharging... and it all depends on your needs. Be aware that right off the bat you wont be able to do this for under $1000.
    And even if you do it for $1000, your motor wont last long.
    The bottom line is, the more you want to push it, the more you have to prep the motor, and eventually the more you will spend on it. I have put upwards of $3k on my setup already.
    The only main part that you should be concerned with getting is the exhaust manifold, which is obviously something that has to be made/adapted to the e30. The cheapest way to get a turbo exhaust manifold is to get a 524td manifold and have it ported to the 325i motor specs.
    The rest is basically universal (turbo/intercooler/etc) so you'd just need to find out what would work best with you. There is a lot of work into it... a downpipe has to be custom made for your car.
    There's a lot more that you'll have to look into it... but it's definetly not as easy as just saying "I want a turbo" and having everything come together easily.
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • Garageaholic
      Freestyle Fabricator
      • Dec 2005
      • 5204
      Search it up brotha
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      Instagram.com/garageaholic
      Youtube.com/garageaholic
      • CarsSuck
        • Oct 2005
        • 968
        go to e30tech.com
        --Will
        • Borat
          • Jan 2005
          • 494
          Originally posted by rwdrift
          Oh boy.
          I just did, not sure how long motor will last though. :D
          • charger5205
            • Feb 2007
            • 10
            wat if its runing at like 6psi?
              • 37833
              It still costs money. Do it once, do it right.
              Grover Beach, California
              BimmerHeads.com
              • backtrail69
                • Jul 2005
                • 4471
                Originally posted by CarsSuck
                go to e30tech.com
                +1 Everyone with an eta and 3 dollars seems to have a ghetto turbo setup over there... but also some big players as well. I have 3-4k into mine so far...
                :: PNW Crew ::
                '87 325 4dr, '74 2002
                • Erick
                  • 11169
                  i'm running 7psi, and I spent upwards of 3k already.
                  Feedback Thread
                  • e30bimmerdude
                    • 272
                    If you are going to turbo, take the time and the $$$..its can be done for cheap if you want a cheap setup, but reliability is key, atleast to me... and not all of us ETA guys from e30tech are el cheapos...:)
                    • Erick
                      • 11169
                      I mean, this is all subjective. My point of view is.... if you want power ASAP, then do it now... even if it's rigged. Just be smart enough to push only as much as your setup can take.
                      Upgrade as you go along and sell the old parts to make up for the money. I just went from a 524td manifold to a Jon Volk adapter after a year.... and I dont regret being cheap at any point in time.
                      Feedback Thread
                      • matt
                        • 3732
                        The turbo diesel manifold is a good way to do it.
                        Jon Volks adapters are the tits also, though.
                        • triggrhaapi
                          • Feb 2007
                          • 350
                          666 fab has some sick adapters for stock manifolds.
                          1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
                          • Borat
                            • Jan 2005
                            • 494
                            Agreed, this is the way I have done it. Just spend some time planning your setup so you don't waste money on the big $ items. Things like oil lines, gauges, manifolds, wideband O2 can all be used over again with different setups.
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              Here's some reading material. If you don't even know how a turbo works or is installed, you have a lot of information to obtain before starting your project. The Meagsquirt link has links to some good books that I have found on Amazon.com for less than $20. You CAN do a turbo for around $1500 if you are machanically inclined/experienced and have access to all the tools/supplies needed (ie welders, machining tools etc). The more you have to have someone else make is more money you are going to spend. If you are incapable of doing extensive custom fabrication, expect to get charged more than $3000 (+ the $12-1500 on parts).
                              john@m20guru.com
                              Links:
