Ebay Turbo Kit???
  • Bryan
    • Jan 2007
    • 118
    Ebay Turbo Kit???
    http://cgi.ebay.com/ebaymotors/BMW-8...91817061QQrdZ1
    Anyone know anything about this setup?
  • Bimmerboy91
    • Feb 2007
    • 622
    yea i saw this one too. any know about it?
    • Bryan
      • Jan 2007
      • 118
      I'll call them in the morning and get the details. Nothing about fuel management in there perhaps would be able to use TCD's setup. The injectors would have to go and you have to custom fab your own downpipe which 666 should be more than capable of doing. On another note the IC core isn't all that impressive. But for $ which is 4k less than TCD's stage II kit you really cant go wrong. I'll share my feedback from them 2morrow night after work.
      • blueapplesoda
        • Dec 2005
        • 1904
        well, before that came out i pretty much bought everything from ebay, including the turbo. Ill tell you that the manifold is good, the intercooler is ok (watch for paper in the tanks!) and pretty much all the main stuff is good. turbo spools up fine, internal wastegate works alright...btw i got a larger intercooler.
        just bsure to hookup the afm in front of the turbo and run an vortech 12:1 with a 2.5 bar stock fpr from an eta along with sometihng like 19 lb injectors and it should get you at least started.
        im running 12 psi with 17.5 lb injectors from an s50 with a 10:1 vortech fmu for fuel enrichment, and 2.5 bar fpr for consistent idling, and my numbers are a little lean, stays around 12.5-13 most of the time, and about 14.5 afr up in the high revs past 6k. It will be corrected soon with a 12:1 so well see. but i am in the midst of tuning all the little problems out.
        this setup worked well for 7-8 psi (AFRs in the 12s all the way to redline) but of course when boost goes up fuel needs to go up so there you go.
        Metric blues dont forget. cooler thermostat, bpr8es ngk plugs
        • Bryan
          • Jan 2007
          • 118
          Well I spoke to this outfit today @ lunch time. The 2nd guy I spoke to told me the turbo is good up to 25 psi. Of course there's no way on God's green earth you could run that ammount of boost on stock internals. I believe for the money it's a reasonable investment. The IC is 2.5" piping and as I said before seems to be inadequate for serious boost. I would feel comfortable running 6-10 psi on that setup. Blueapplesoda if you wouldn't mind I'd like to pick your brain sometime on the M20 and forced induction.
          • E30 Reaktionär
            Site Manager
            • 14451
            Did they say what brand the turbo was?
            1992 BMW 325iC
            1978 Chevrolet Monte Carlo
            • Bryan
              • Jan 2007
              • 118
              No, they did not say. Prob some bo bo brand lol I dont know. Honestly both guys I talked to in the shop sounded like hector from fast and furious I 1/2 way wanted to ask if he sold nosssss
              • dele30
                • 116
                if i bought that setup and didn't like the turbo, do you think it would be easy to swap for a better turbo?
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  yes. im going for a gt3071r after this pos shits.
                  • HST
                    • Jan 2006
                    • 757
                    On the other thread people seem to have very different thoughts about the manifold. How long have you been running yours, and did it seem cheap?
                    Originally posted by KingB
                    Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
                    • TopOfTheLine89
                      • Jun 2007
                      • 919
                      well did it seem cheap??... sorry for bringing this stoneage thread back to life but i just have to know.lol.
                      97 tacoma 5 spd 4 cylinder
                      2001 330ci 5 speed
                      83 733i 5 speed, (FS)
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        Most of those kits are made with 304l stainless, not the best for a turbo manifold due to heat cycles. I have one of those Chinese brand turbos on my Firebird and have not had any problems with it. Blueapplesoda, you might be waiting a while for the pos ti die, my friend has over 70k miles on one pushing 16psi. It appears the turbo is a to4e,a Garrett copy that can even be rebuilt with Garrettt bearings. I have found the turbos from China are usually mis-advertised on their trims, me amoung others have measured the turbine wheels and came up with a 46 trim, not 57. Far less efficient than a 57trim (capable of about 42CFS).
                        If you haven't had problems with the headers, you will and I suggest bracing the turbo and/or headers to help prevent cracks. The way you can tell if it is 304 (especially 304l) is weather or not it is ferrous (magnetic).
                        And yes they sre demensionally the same as a Garrett t3 flange and a Garrett will bolt in place of it.
                        john@m20guru.com
                        Links:
                        • StereoInstaller1
                          GAS
                          • 22679
                          I just love the line in the ad: CUSTOMER IS REQUIRE TO CUSTOM MAKE THE DOWN PIPE
                          I would love to see someone buy one of these kits and install it, just as it is.
                          Maybe it will be me!
                          Luke
                          Closing SOON!
                          Thanks for 10 years of fun!
                          • vlad
                            • 0
                            what about the ECU ? What programming needs to be done if any, different chip ?
                            • Bryan
                              • Jan 2007
                              • 118
                              Just buy Todd's chip from TCD
