The whole concept of a "thicker" HG doesent make much sense to me. It seems like your taking 3 steps back just to take 5 steps forward. i know what your thinkin please read on.
**Please dont get caught up in the actual numbers im making up(their just examples), im refering more to the concept or "theory" of things...
Using thicker HG will lower the compresssion of the engine, but if you lower your stock compression, your motor will obviously be underpowered until you can reach boost. So your underpowered from say idle-4K rpm.
So say you have a 2 engines, one with stock compression boosting 10psi, then you have another engine with a thicker HG boosting 15psi,(they have equal compression when their at their full boost levels) wouldnt it take the engines the same amount of "time" to get from say 0-100mph(thats all i care about).
**HP and Torque numbers dont mean a thing, the actual amount of time it takes you to get your car from one speed to another speed is the only thing that matters.
I see people use the thicker HG and boost say 15psi, if they just kept the stock HG size and boosted say 10psi, wouldnt it be the same??
--I understand a thicker HG adds displacement, thus more room for compressed air, but come on it cant be adding that much room to create a HUGE difference.
Please i would like to see your point of view on this "concept" becuase so far it seems like you should just put your $$ somewhere else for power gains...
