Info Needed For Turbo Build
  • TWM-M42
    • 26
    what rods, pistons, crankshaft, cams, ect should i used to build a healthy M42 Turbo motor in a 1991 bmw 318is?
  • Jbpka06
    • Feb 2006
    • 551
    check out m42club, no one puts turbos on m42s
      • 34839
      that's because they're too cheap to shell out for turbo pistons and proper EMS :p
      check e30tech for turbo info - you should be able to do it with the stock rods and crank, but you will need custom pistons with a lower CR - something like JE 85mm 8.5:1 would work :)
      • newman
        • Mar 2007
        • 1159
        it's funny when people buy a turbo before they buy anything else.
        1987 325is: 495whp/400ft-lb
        UPDATED 03/12/10!: RB26DETT Swapped E30
