Car falls flat on its face at ~5000 rpms in boost?
  • Danny
    • 14216
    Fuel pump dieing?
  • Pinepig
    • Sep 2007
    • 1811
    How much PSI, could be blowing the spark out, what kind of ignition system are you running.
    • Danny
      • 14216
      8 psi.
      Stock ignition.
      I had to running fine this morning, then this afternoon it started doing this. I think the fuel pump finally gave up the ghost.
      • Holland
        • Nov 2008
        • 7176
        Reliability, FTW. Lol sorry, I had to say that. but still that sucks.
        Originally posted by DEV0 E30
        • Danny
          • 14216
          Alebit the ignition is controlled by MS, but its the stock coilpacks.
          • Erick
            Official R3V Drifter
            • 11169
            No whine from the pump? Check fuel pressure?
            ..::Support FullOpp::..
            FullOpp Stickers for sale!
            Feedback Thread
            • Danny
              • 14216
              LOTS of whine from the pump.
              When I rev it with MS connected the gauges on the laptop show the fuel pressure goes to negative.
              I'm pretty sure its the pump, just wanted to see if there were any other ideas.
              • wolfgangstbd
                • 960
                when my fuel pump died my car actually couldnt stay alive unless it was about 3000 rpm but it wouldnt even reach five.. oh i would have to say the biggest symptom i noticed is the rpm's would bounce around alot at idle by like 2-4 hundred rpms. and it got worse after being on brakes kinda hard
                • dashboardmonkey
                  FUCK YOUR WAFFLES
                  • Jun 2008
                  • 6158
                  Whack the panel above the fuel pump a couple time with a rubber mallet when it starts falling on its face.
                  -Andy
                  • Rolla1990
                    • 199
                    I had this problem when I first went MS, it turned out to be the overboost protection setting in the tune. I had it set too low so it would cut the spark out once the car reached full boost. Maybe your boost controller is letting your car overboost?
                    Turbo M20, MSnS, 38lb, 3" no cat, RPI 12.2", ATS DTC, 240whp/240wtq, Lmnop. www.DonsGarage.net
                    • xwill112x
                      • Jan 2009
                      • 4236
                      that should be a immediate indicator.
                      if i were you, i'd replace the fuel filter while i was replacing the fuel pump. ;)
                      • Jbpka06
                        • Feb 2006
                        • 551
                        Doesnt there have to be something sending a fuel pressure signal to the MS for that reading to be accurate? I didn't think there was a fuel pressure signal unless you added an aftermarket gauge sender.
                        • blueapplesoda
                          • Dec 2005
                          • 1904
                          Fuel filter? I used a walbro in my setup and they use these stupid little sump filters that get dirty and clogged really fast and caused my car to choke up and the afr's went lean around higher rpm/boost. Could be a problem.
                          • blueapplesoda
                            • Dec 2005
                            • 1904
                            On second thought if u used an fpr (pre-ms) with the stock fuel pump then your pump probably failed.
                            • Danny
                              • 14216
                              Thats what M3Ryan said as well when I called him.
                              I already ordered the pump and I'll get the fuel filter as well.
