forced induction question
  • whterice
    • Jan 2009
    • 258
    do you guys recommend doing a cam with forced induction?
  • StereoInstaller1
    GAS
    • 22679
    Yes, you should have a cam.
    Closing SOON!
    Thanks for 10 years of fun!
      • 34844
      absolutely. a good N/A cam is also going to be a good turbo cam.
      • whterice
        • Jan 2009
        • 258
        what do you recommend for a good cam? mine is worn and broke a rocker
        • gothguy70
          • Nov 2008
          • 21
          A new stock replacement cam should be fine for a while.And fix the broken rocker ofcourse.Upgraded valve springs should go in with the new cam.
          • Spinning Tires
            • Feb 2007
            • 283
            Stock cam is the best unless you find a company that makes a turbo cam cause an aftermarket N/A cam will NOT work well
            First: 1984 318i
            Second: 1987 325
            Third: 1987 325is
            Current: 1990 325i (Soon To Be 335i)
              • 34844
              again, not true.
              convention wisdom pwns j00.
              • Spinning Tires
                • Feb 2007
                • 283
                Most companies making an N/A came make the lobe separation too big causing the built up exhaust pressure to back feed through the intake
                First: 1984 318i
                Second: 1987 325
                Third: 1987 325is
                  • 34844
                  if you have that much exhaust back pressure then your exhaust is too small.
                  look at what the guys in scandanavia are running. there is a reason people here struggle to produce 300whp and people over there do 500whp in their sleep.
                  • Liam
                    • 753
                    Turbocharging is a little outside of my scope of expertise but I must agree here always have a cam in your engine, I don't think they will run at all otherwise.
                    I have been told by a power-plant wizard that big overlap is not your friend with turbocharged engines and delaying intake opening is the trick (this is hearsay, take it with a grain of salt then go research it thoroughly).
                    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
                    • whterice
                      • Jan 2009
                      • 258
                      what duration of cam do you recommend?
                      • Spinning Tires
                        • Feb 2007
                        • 283
                        what kind of motor is this for?
                        First: 1984 318i
                        Second: 1987 325
                        Third: 1987 325is
                        • Spinning Tires
                          • Feb 2007
                          • 283
                          exhaust pressure before the turbo is always going to be more then intake pressure
                          First: 1984 318i
                          Second: 1987 325
                          Third: 1987 325is
                          • whterice
                            • Jan 2009
                            • 258
                            1990 325i so m20b25
                              • 34844
                              heh, for some reason I thought you were building a 24v motor.
                              I still would reccomend a decent cam. what are you using this for? I'd look into what blacktrail69 used, he was making over 300whp at 10psi with a 280 degree or so duration catcams. The shrick 288 would also be a good choice if it's more of a race/fun car than a DD.
