Explain turbo maps to me...
  • Aptyp
    • 6584
    How would you put e30 m20b25 on a compressor map? What flows, how do you calculate all that.
    How do some of you run cars on stock ecu? with stock AFM? how much boost and what kind of gains?
    I am a turbo nub, with Pro-Turbo manifold and a whole lot of turbo parts.
    I've read through a lot of this subforum, I just want a little bit of direct answers. Thanks, guys.
  • blueapplesoda
    • Dec 2005
    • 1904
    i thought the stock ecu was OK for turbo, and i ran about 8-10 psi through it, dynos around 235whp/235tq, since the afm was so far away from the engine, throttle response fails.
    then i found out motronic was shit after i installed and properly tuned an MS system into the e30. Throttle response, fully capable of almost everything you need to change.
    Stock ECU+FPR = pile of dog shit that will get you by for a few months.
    • mooseheadm5
      • Apr 2009
      • 375
      It is a lot to explain it to you. I recommend:
      http://www.amazon.com/Maximum-Boost-.../dp/0837601606
      -P
      Moosehead Engineering
      • Danny
        • 14216
        I ran a blow through afm at 7 psi for about a month.
        • yberther
          • 1246
          more relevant.
          This was posted on tech....
          http://forums.bimmerforums.com/forum...d.php?t=638158
          Flickr
          Originally posted by Indecline06
          For some reason, when I get super duper ultra stoned... The M30 motor reminds me of big bird from sesame street.
          • TS87325IS
            • Sep 2006
            • 821
            Iam running a blow through m30 afm at 7 psi , and it's working fine , havn't dynoed yet but its a good bit more than stock according to the butt dyno:)
            mods: just meat and potatoes under the hood and wheaties on fire out back ;)
            • yberther
              • 1246
              really relevent....
              Flickr
