What would be a "warmed up" temp?
  • Jean
    • 18228
    What would be considerd a "warmed up" operating engine temperature? I just want to confirm if my coolant temp sensor is bad by replacing it with a resistor of the right value to see if it will drop my idle. I am just not sure what temp would be considered as "optimal"?
    Thanks.
    m10
    GAUGE READINGS!!!
    Coolant temp (F) Gauge sensor (ohms)
    186 64
    166 73
    161 87
    145 126
    137 143
    122 200
    107 267
    99 309
    89 367
    81 440
    Part Numbers
    m10
    04 TEMPERATURE-TIME SWITCH 35CEL 8S 13621274630 $72.54
    06 TEMPERATURE SENSOR, WATER 20CEL 2500 OHM 13621357414 $44.36
    08 TEMPERATURE SENDING UNIT/WARNING CONTACT 45CEL 12621285073 $64.17
  • Beach Bum
    • 466
    180. I think that's a hair over the middle of the idiot gauge.
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • e30trooper
      • 11576
      my car idles at 1500 till its right past the Blue mark on the temp gauge then drops to 900,
        • 34844
        I don't understand US measurements for engine temps.. so whatever is close to 75-80c.
        • Jean
          • 18228
          When I disconnect the coolant temp sensor, idle drops from about 2k to just under 1k... Tried a couple different things, but gave up on it. I really can't stand it anymore.
          Hope this helps others :
