e30 m10 weird ICV setup
  • JMe46
    • Nov 2024
    • 4
    Click image for larger version  Name:	IMG_0189.jpg Views:	0 Size:	200.2 KB ID:	10130988 Noticed my ICV setup was rtoated 180 degrees and there is an extra ICV plug... any ideas why this would be this way? My assumption was a shop the p/o did it and didnt have the right hoses but that seems way more complicated wiring in a new icv hose then just waiting for new parts
    1985 318i
    p/o drove this car home from the port when it was imported
  • KI4UJO
    • Jun 2011
    • 642
    ICV orientation looks normal from when I had my M10.... I believe the other plug goes to a solenoid valve for vacuum advance. It usually sets on the rear firewall cover (below wipers).
    IMG_0145 by Jonathan Martin, on Flickr
    • JMe46
      • Nov 2024
      • 4
      Interesting. A lot of cars i've seen have the ICV plug side facing the firewall (mine faces the front) but thank you.
      • robertloll1
        • Jul 2021
        • 11
        That might be an unused connector. The E30 M10 engine wiring harness had an unused connector at the firewall in that location.
        • BadDays
          • Dec 2024
          • 181
          Yup, That's a three port styled icv which my car didn't even have, However the hoses route to a solenoid valve on the firewall and they also go to the intake boot I believe.
