engine bogging down when i let go of the throttle at high revs
    i have a 1985 318i
    whenever I let go of the throttle at high RPMs and try gunning it again immediately it will bog down for a second or two. It has a 5 speed so i know its not the tranny trying to shift itself, though it does feel very similar to that.
    It happens in almost all RPM ranges and all 5 gears.
    I also have problems when I start it up cold. the engine will rev around 400rpm and end up shutting off. Once it is warmed up after driving around a block or two, it will rise to 600rpm, and eventually to 1100rpm when idling and be fine.
    I was wondering what these two problems could be coming from?
    thanks in advance
    sounds like fuel problem. Fuel filter + fuel pump??
    '89 325i - Totaled... good bye my love...
    '87 327i budget stroker - SOLD!!!
    '92 240sx - ca18det powered drift toy - SOLD!!!
    '89 325i - coupe - NEW daily
    '96 Audi A6 Quattro- Grocery getter/baby hauler
    '99 Busa - weekend wheelie monster
      Pull the vacuum hose on your fuel pressure regulator and see if fuel comes out. If so you need a new regulator.
