My car idles anywhere from 1500 rpm to 2000 rpm cold or warmed up. Once it's started if I unplug what I would say is the cold start valve or idle control (I'm still a noob with these cars) it will idle way up until I plug it back in.
If I unplug the little harness that goes to the thermostat housing/waterneck from the idle control it idles right around 1000 rpm if I set it there with the throttle cable stop, but it runs like a piece of fuck under load like that. What I'm thinking is that the sensor that tells the idle control/cold start that the car is up to operating temp has gone bad, so it's constantly thinking the car is still cold and trying to compensate.
Does any of that make any sense, or am I way out in left field with all this?
