My friend has an e21 '82 320i auto and i want to know if there is anyway i can use the auto radiator from my '90 325is on his e21? thanks!
E21 Question
E21 Question
Tags: None -
honestly you could but it would require some modding. AND im not entirely sure if it could physically fit due to sizing but...
1. the m20 radiator doesnt have a fil cap; it uses a reservoir. to get around this, you could cut the upper hose and clamp in a remote water neck filler.
http://cgi.ebay.com/ebaymotors/Summi...Q5fAccessories
2. do you want to use the stock transmission cooler? the location may differ from the m10 rad and m20 rad as with the fittings. When i used a manual rad in my auto m10, i just routed the transmission lines to a regular oil cooler from a truck...
3. how are you going to mount it? like i said earlier, it may not fit physically, i dont know the dimensions of the e21/e30 but if it does, it shouldnt be to hard. from looking at the inlet/outlet of the radiator, you probably just need to extend the hoses a little bit
this is how i would go about putting an m20 radiator in an m10 e30? -
