I think my friend ran his 318i out of oil. What would that sound like?
  • Wishno87
    • 6025
    It periodically has the worst squeaking/chirping sound. Not all of the time but most of the time. Its coming from the 4th cyl area. It was about 2 quarts low.
  • Exodus_2pt0
    • 5943
    2 quarts low shouldn't cause any damage.
    Squeaking can be anything from belt to cam bearings. However unless he ran it so low that the oil pressure light came on, I doubt he hurt it.
    No E30 Club
    • Wishno87
      • 6025
      I don't think the car has a working oil pressure light. Is it possible the oil pump failed? When I run it for a couple seconds a strange burning smell comes out of the oil filler hole.
      • Exodus_2pt0
        • 5943
        Dude that is a huge no-no!
        It is entirely possible that the pump failed, and with no oil light to send a red flag things could be toasted by now. I would not run that thing for another second until you hook up an oil pressure gauge and find out what is going on.
        When you do hook up the gauge, make sure to disable the fuel and ignition system. Then crank it for 20-30 seconds and see if you build pressure.
        Also just turn the key on with the engine off, if the light does not come on, then it doesn't work.
        No E30 Club
        • Wishno87
          • 6025
          I think he already drove it home like that lol. I was already assuming its done. I will pull the valve cover when I get a chance to tow it home. So you think one of the bearings or rings was run dry?
          • Holland
            • Nov 2008
            • 7212
            Eh it's an M10, it will just limp it off.
            Originally posted by DEV0 E30
            • Hey_You
              • Nov 2009
              • 963
              m10, no performance to be hurt, it'll buff out.
              85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
              • Wishno87
                • 6025
                Ya im hoping to just find a cheap/free long block and swap it over.
                • Ryann
                  • 3350
                  Requesting picks of bearing destruction!:D
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    isn't 2 quarts about 1/2 the oil capacity? lol
                    • Wishno87
                      • 6025
                      Thats what i was thinking lol. The M10 has a little pan. The M50 takes 6-7 quarts but even the M20 is only around 4.5.
                      • xwill112x
                        • Jan 2009
                        • 4236
                        m50 time :)
                        • Wishno87
                          • 6025
                          Originally posted by xwill112x
                          m50 time :)
                          Lol he would kill himself. Really though if he can't keep oil in an M10 I don't see it making sense to put a much more expensive motor in. We are getting his eta automatic all ready for him though :giggle:
                          • Holland
                            • Nov 2008
                            • 7212
                            M10 is 4.5 to 5, about.
                            • irish44j
                              • 2763
                              ...and you're sure it's not your blower fan squeaking, right? Because that is only a few inches from the 4th cylinder area of the valve cover. And mine was making quite a racket recently due to bad bearings.
                              Probably not, but might as well throw out the simple solution just in case ;)
                              Stage rally/rallycross e30 build/competition journal
                              Track/street e21 build
                              visit Condor Speed Shop
                              visit Motorsport Hardware
                              [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
