ok so like the title said what i want to know is if i can put a 2002 m10 into my 318i, and oif so dose it fit my g240 tranny. im looking at doing a mild build and i want to use the 2002 engine. so please any info would be good i did some serching and saw people useing the 2002 block with the 318 top end. is this better? i want to make 180ish in power really want 200 but hey money is always an issue but anyway o and i know tons of people are just going to say TURBOOO IT!! but i dont want to right now maybe latter. so please any real advise is going to be hugly appresated.
2002 engine in an 318i, can i do it?
First off, I'll throw out the obligatory statement that you can install whatever engine you want in the car with enough fabrication.
As far as I know the blocks have different bosses for the engine mounts, so you're gonna need something custom. For the head you're going to want one that matches the pistons you're using. Which head is best is a toss up. I've seen various threads comparing the flow rates of one to the chamber shape of another. It's something you can decide for yourself on which is best. The 2002 guys do 5 speed swaps all the time, so getting a tranny to mate won't be a problem.
Looks like you've still got a lot of searching to do.
hey, hey you i thought about pming you but i figured you would post something sooner or latter. and ya i was wondering that to what your porjected hp with that set up will be. and should i stay with fuel injection or should i do a double carb kit and keep the 2002 top end as well. i was thinking about doing the pistions ( not sure whitch ones) with a scheric 292 cam and a few other things.
I'm gonna hope for 250-300whp. I'm still a long ways off from running a boosted engine. It's in the works, just had a hiccup. Everything bolts up the same (minus the passenger side mount as I have said). If you want carbs to adjust/tune depending on elevation, want poor cold start driveability, go for it. You will have higher output from a carb'd m10 (as you can re-jet for more aggressive cams) but I prefer fuel injection. Just remember 2002's camshaft/distributor are different than the 318i. If you are looking for that much power from an m10 without boost, don't expect it to be a pleasant daily driver. That power will almost ALL be up top in the power band, and your lower RPM power/torque will suffer
Forgot to mention another difference between 318i blocks and 2002 blocks, the 2002 block does not have bolt holes to mount the flywheel cover/guard thing that the 318's come with. You can still use the guard, but it won't bolt to the block unless you do some drilling (which I chose not to do). It is being held on with 4 bolts to the transmission. The 2002 crank gear is a double chain setup. What you can do is use a single row chain on it with the 318i head. (works just fine). On another note, my hodgepodge setup roared to life today for the first time. Can't wait to actually drive it in the next few days
Congrats man! I'm doing the same as you for the cover plate. I've got an e21 block and just have that plate bolted to the tranny. I've been meaning to try and find out what e21's have there. I'm curious if it could possibly cause some problems later down the road when I turbo the 318 since it has less bracing from engine to trans.
just fab up braces. i see no problem-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good looking
