2002 engine in an 318i, can i do it?
  • rhE-30
    • 498
    Originally posted by Exodus_2pt0
    Calm down man.
    I read it and in my head I heard it like my sister talks.
    • Hey_You
      • Nov 2009
      • 963
      Here is a handy link over at BMW2002FAQ. Cylinder head CCs volumes, pistons, block and CR Should help give an idea of compression ratios and such depending on what pistons you have in your 2002 block with whichever head you use. I'm not quite sure how to do the conversions, maybe someone could point me in the right direction so I could learn. I have the e12 pistons in my block, which were rated 8.3:1 CR. That is with the e12 head which has a 61cc combustion chambers. The 318i head is rated at 63cc (I have also heard 65cc but can't find where). If the ration is 8.3:1 with 61cc, what will the drop be due to the added 2cc in the cylinder head?
      After looking around some more, I'm finding that the e12 piano pistons are rated 9.0:1 ratio? I'm confused now and need a straight source.
      85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
      • thebutterson
        • 463
        Originally posted by Teaguer
        You can definitely run an '02 M10 in your M10 but only if you plan on running an aftermarket ignition system.
        The distributor turns in the opposite direction than the later M10's so you can't run your same ignition.
        The distributor does turn the opposite way, but you can swap the gear on the distributor so that it works. 2002 guys do that so they can run their engines on l-jet. No aftermarket ignition required.
        http://www.bmw2002faq.com/component/...ef6ed5dcf4ba7/
        • MikeM10
          • Sep 2011
          • 19
          Id like to know if you can just change out the crankshaft from the 2.0L block into the stock bottom end of a m10b18, would it fit right over? that way I wouldnt have to get the whole bottom end and just keep my own and give it a higher stroke. any input?
          • SoopaGhetto
            • 573
            all m10 parts fit in all m10 blocks.
            you can put a 2.0 crank into any m10 block including the 1.8 block, but you must have the 2.0 pistons or custom. the rods are the same length, for the 1.8 though the 2.0 are thicker.
