240 transmission shifter slop
  • E30_Pare
    • 7801
    So I've got a couple inches of shifter slop. What bushing do I need to change to eliminate this shifter has no feel at all. I heard there are some plastic pieces inside the trans that get worn out that cause slop. Anyone chime in?
    DREWLIENTE
    1$ PShops PM me
  • Hey_You
    • Nov 2009
    • 963
    There are a bunch of parts to replace. Somewhere...someone made a write-up on how to install needle bearings on all the slop parts to COMPLETELY eliminate slop. Sorry I couldn't be of more help
    85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
    • thebutterson
      • 463
      Just pull up the parts breakdown on realoem.com and order all of the bushings, washers ect for the linkage. Pelican usually carries most of the parts.
      • E30_Pare
        • 7801
        The shifter carriage is all new still didnt solve much. Which is why I suspect its internal. This is the second trans with the fresh carriage same results on both. I have a spare 240 laying around which I can work on so I can rebuild & swap in. Also I need some help getting the shifter center (sitting slightly off centered). I've moved the trans & motor mounts around, but can't seem to get it centered. Any tips?
        DREWLIENTE
        1$ PShops PM me
        • E30_Pare
          • 7801
          Oh and I don't have reverse lights. Had this issue before, but the wires got cut going to the sensor on the trans. This time just went out completely. Sensor works & I've followed the wiring all the way back to the taillights no shorts. Anything else I should check?
          DREWLIENTE
          1$ PShops PM me
          • Hey_You
            • Nov 2009
            • 963
            My wires got chopped too. I haven''t fixed it. I haven't needed to swap my trans to fix any slop, but that my be your problem. I know mine would be take care of if I did the needle bearing swap, but since I haven't, I have a little north south slop, but east west slop has been taken care of.
            • E30_Pare
              • 7801
              I've got complete NSEW slop. Haha. It's quite annoying not having reverse lights
              DREWLIENTE
              1$ PShops PM me
              • kway
                • 1084
                The shifter rod itself could be worn out. The pins can wear to the point that they don't fit snugly even in new bushings.
                '84 318i - Lapisblau/Schwarz (in cryosleep)
                '06 330i - Titansilber/Schwarz
                • E30_Pare
                  • 7801
                  I'll look into that. That's the one part of he shifter I didn't change. I actually snapped one of the ends off once & just welded it back together so I guess I should get a new one anyways
                  DREWLIENTE
                  1$ PShops PM me
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    biggest difference for me was new T bushing thing. The rod that connects the gear shifter goes through it.
                    • E30_Pare
                      • 7801
                      Any more specific? U talking about the connector piece on the trans?
                      DREWLIENTE
                      1$ PShops PM me
                      • Jaxx_
                        • Dec 2009
                        • 1880
                        http://www.realoem.com/bmw/diagrams/l/t/7.png #16
